Extracting attributes for current date
I have this entity and want to extract the values of current day into entities through templating. Can anyone help me?
entity:
sensor.kona_daily_driving_stats
Returns:
2023-12-01:
total_consumed: 7568
engine_consumption: 5174
climate_consumption: 1524
onboard_electronics_consumption: 870
battery_care_consumption: 0
regenerated_energy: 2618
distance: 48
Tried this, but doesn’t work. Returns 0
{% set attr = state_attr(“sensor.kona_daily_driving_stats”, now().date()) %}
{{ 0 if attr == None else attr[“total_consumed”] /1000|int }}
Please format your code correctly.
It’s not completely clear from your post what the entity state and attributes are. Please post a screenshot like this showing it:
or the properly-formatted output of this in the TEMPLATE editor:
{{ states.sensor.kona_daily_driving_stats }}
In addition to everything Troon said:
now().date() isn’t a string and state_attr() expects a string value for the attributes name. To get the date string use now().date() | string.
{% set attr = state_attr("sensor.kona_daily_driving_stats", now().date() | string ) %}
{{ 0 if attr == none else (attr["total_consumed"] /1000) | int }}
Here is a screenshot:
Many thanks for your kindness
In that case, Drew’s suggestion above should work for you. Just turn the date into a string, and make sure you are applying int to the whole statement not just the 1000.
Works. :slight_smile:
Many thanks to you both
/Lars
Hi Lars, please take the time to mark the answer as solution, you do that by selecting the three dots under the post:
Then select the check box:
By doing so this can be useful to other users as well and prevents that someone else steps in and still tries to help you.
