Hi community
I have a couple of Shellies to control my home and try to build an automation in Nodered using a Shelly Button 1 and two lights. I use MQTT to get the buttons data as per https://shelly-api-docs.shelly.cloud/#shelly-button1 it has different push types I want to make use of.
automation I try to build
Shortpush = S | If shortpush is reported toggle light 1
Double Shortpush = SS | If double shortpush is reported toggle light 2
The payload from the button is
First I use a switch node to check if the msg.payload is of type string.
Then I use two switch nodes (I could probably use one) to determine if the string contains S or SS
The issue
If I use shortpush light 1 toggles, If I use double shortpush light 2 toggles BUT light 1 toggles too. This is probably because the string SS containts the letter S as well.
I did some research (here and in the internet) but could not find the solution for it. Could you please help me to get this thing running? I do have basic-knowledge of Nodered but very little in terms of JSON etc.
BTW: I am very happy to be part of this community and can hopefully help others some day.
Kind regards from snowy Switzerland
Andrew
