Hi all
I hope to be able to extract some custom data from the history log by specific times. In this case, I want my imported grid data from my solar setup, but at a different time to the default midnight to midnight.
As the import effectively ceases as the sun rises I would like to extract the import data from (nominally) 6am yesterday to 6am today as a number.
On this screen grab you can see that the data exists, and on the day depicted a total of approximately 8 kWh would be the response.
I have approached this via the history_stats
sensor explained here:
with the following entry into configuration.yaml
- platform: history_stats
name: Grid Input Last 24
entity_id: sensor.power_grid_in_today_kw
state: "*"
type: count
end: "{{ now().replace(hour=6, minute=0, second=0, microsecond=0) }}"
duration:
days: 1
The response in sensor.grid_input_last_24
is zero when the history shows approximately 1 kWh for the recent 24 hours.
I note that the ‘type’ string limits to time
, ratio
, and count
so I assume these do not aggregate the data over the period. I have tried the other two without (as expected) success.
I have searched the forum without success
Are there any suggestions to achieve what I want? Thanks for reading
