Extreme loading times
I had an issue in my database getting corrupted so I had to roll back a backup. As I performed some significant edits I restored configuration.yaml and the esphome yaml files (copied manually before rolling back the backup) after rolling back the backup.
Everything appears working fine now, but Homeassistant is slow as as a snail despite running on a beefy NUC and never having issues with performance previously. Also in the logs nothing major is being reported. Have tried the usual (restarting host etc) but nothing appears to solve it.
If I look at the CPU usage of the NUC it is running below 50% all the time, but when I look into the devtools of Chrome I see that websockets might be causing the problem. How can I solve this?
NOTE: running latest version of homeassistant and esphome…
