I’ve long had trouble with this automation because I can only sort of test it and find out it’s not working when there’s an extreme weather event. Which is or has been relatively rare in England. Anyway…
subscribe to the event in the event tab and see if the event’s working as expected. Also, you’re missing data_template which is required for templating.
When I go to the feed there is very much an active alert…but it does take ages to load.
And it’s weird that I only get an error in my logs about the automation when there IS an active alert otherwise it’s all quiet on the feedreader front…
