I recently paired a EZMultiPli (HSM200) Z-Wave motion sensor. I am seeing LUX/Temp, as well as Burglar (motion), however I do not see a way to turn on/off and set the color of the LED. This device implements the COMMAND_CLASS_COLOR, which is in the zwcfg XML. Any help is greatly appreciated, thanks!
Any motion on this? Another great device I’d love to see supported.
I do see HSM200.xml in the openZW config, but I don’t see anything about lighting control in here.
Unfortunately I haven’t made any progress - I haven’t had much time to look into this and I’m still getting used to the development side of Home Assistant (coming from SmartThings). I’m itching to buy 2+ more of these, so hopefully we can get the integration fully figured out. I’m sure this is a very easy fix for someone more familiar…
Thanks, appreciate the update. I’m also coming from SmartThings, and the amount of manual intervention required is a bit painful so far, so I feel your pain.
I played around some more and in OpenZWave Control Panel I can set the LED color under Current Values.
Here’s the logs of setting the color. Hopefully there’s someone more familiar with the Z-Wave integration that can point us in the right direction…
2018-05-30 21:59:16.681 Info, Node041, Value::Set - COMMAND_CLASS_COLOR - - 1 - 1 - Red
2018-05-30 21:59:16.682 Info, Node041, Color::SetValue - Setting Color Index Value (Fake)
2018-05-30 21:59:16.682 Detail, Node041, Queuing (Send) ColorCmd_Set (Node=41): 0x01, 0x10, 0x00, 0x13, 0x29, 0x09, 0x33, 0x05, 0x03, 0x02, 0xff, 0x03, 0x00, 0x04, 0x00, 0x25, 0xaf, 0x99
2018-05-30 21:59:16.683 Detail, Node041, Queuing (Send) ColorCmd_Get (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x33, 0x03, 0x02, 0x25, 0xb0, 0x6b
2018-05-30 21:59:16.683 Detail, Node041, Queuing (Send) ColorCmd_Get (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x33, 0x03, 0x03, 0x25, 0xb1, 0x6b
2018-05-30 21:59:16.683 Detail, Node041, Queuing (Send) ColorCmd_Get (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x33, 0x03, 0x04, 0x25, 0xb2, 0x6f
2018-05-30 21:59:16.684 Detail,
2018-05-30 21:59:16.709 Info, Node041, Sending (Send) message (Callback ID=0xb0, Expected Reply=0x04) - ColorCmd_Get (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x33, 0x03, 0x02, 0x25, 0xb0, 0x6b
2018-05-30 21:59:16.718 Detail, Node041, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-30 21:59:16.718 Detail, Node041, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-30 21:59:16.733 Detail, Node041, Received: 0x01, 0x05, 0x00, 0x13, 0xb0, 0x00, 0x59
2018-05-30 21:59:16.733 Detail, Node041, ZW_SEND_DATA Request with callback ID 0xb0 received (expected 0xb0)
2018-05-30 21:59:16.733 Info, Node041, Request RTT 22 Average Request RTT 22
2018-05-30 21:59:16.733 Detail, Expected callbackId was received
2018-05-30 21:59:16.747 Detail, Node041, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x29, 0x04, 0x33, 0x04, 0x02, 0xff, 0x16
2018-05-30 21:59:16.748 Detail,
2018-05-30 21:59:16.748 Info, Node041, Response RTT 37 Average Response RTT 36
2018-05-30 21:59:16.784 Detail, Node041, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x29, 0x04, 0x33, 0x04, 0x03, 0x00, 0xe8
2018-05-30 21:59:16.785 Detail,
2018-05-30 21:59:16.785 Info, Node041, Response RTT 36 Average Response RTT 36
2018-05-30 21:59:16.785 Detail, Node041, Expected reply and command class was received
2018-05-30 21:59:16.785 Detail, Node041, Message transaction complete
2018-05-30 21:59:16.785 Detail, Node041, Removing current message
2018-05-30 21:59:16.785 Info, Node041, Sending (Send) message (Callback ID=0xb2, Expected Reply=0x04) - ColorCmd_Get (Node=41): 0x01, 0x0a, 0x00, 0x13, 0x29, 0x03, 0x33, 0x03, 0x04, 0x25, 0xb2, 0x6f
2018-05-30 21:59:16.795 Detail, Node041, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2018-05-30 21:59:16.795 Detail, Node041, ZW_SEND_DATA delivered to Z-Wave stack
2018-05-30 21:59:16.809 Detail, Node041, Received: 0x01, 0x05, 0x00, 0x13, 0xb2, 0x00, 0x5b
2018-05-30 21:59:16.809 Detail, Node041, ZW_SEND_DATA Request with callback ID 0xb2 received (expected 0xb2)
2018-05-30 21:59:16.809 Info, Node041, Request RTT 22 Average Request RTT 22
2018-05-30 21:59:16.809 Detail, Expected callbackId was received
2018-05-30 21:59:16.824 Detail, Node041, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x29, 0x04, 0x33, 0x04, 0x04, 0x00, 0xef
2018-05-30 21:59:16.824 Info, Node041, Response RTT 37 Average Response RTT 36
2018-05-30 21:59:16.824 Info, Node041, Received a updated Color from Device: #FF0000
2018-05-30 21:59:16.824 Detail, Node041, Refreshed Value: old value=#008000, new value=#FF0000, type=string
2018-05-30 21:59:16.824 Detail, Node041, Changes to this value are not verified
2018-05-30 21:59:16.824 Detail, Node041, Refreshed Value: old value=13, new value=3, type=list
2018-05-30 21:59:16.824 Detail, Node041, Expected reply and command class was received
2018-05-30 21:59:16.824 Detail, Node041, Message transaction complete
2018-05-30 21:59:16.824 Detail, Node041, Removing current message
2018-05-30 21:59:16.824 Detail, Node041, Notification: ValueChanged
2018-05-30 21:59:16.824 Info, Notification: Value Changed Home 0xe73716c2 Node 41 Genre user Class COLOR Instance 1 Index 0 Type string
2018-05-30 21:59:16.824 Info, Notification: Value Changed Home 0xe73716c2 Node 41 Genre user Class COLOR Instance 1 Index 1 Type list
