Greetings, I have a battery powered esp32 so I need to reduce power consumption as much as possible but I am not able to put a EZO ph circuit in sleep mode.
my idea was to use “on_turn_on/off” of a switch to send command to ezo, but it does not work; moreover, the ezo circuit remain in stand-by as soon as I turn off the carrier board
esphome:
friendly_name: ESP-TORRE
platform: esp32
board: nodemcu-32s
on_boot:
priority: 600
then:
- script.execute: check_deep_sleep #all'avvio controlla helper "no deep sleep"
- switch.turn_on: Solar_manager_switch #all'avvio accendi il solar manager
- switch.turn_on: EZO_circuit_switch #all'avvio accendi EZO
on_shutdown:
then:
- switch.turn_off: Solar_manager_switch
- switch.turn_off: EZO_circuit_switch
switch:
- platform: gpio #EZO carrier board
pin: $EZO_circuit_pin
internal: true
on_turn_on:
- lambda: id(PH_ezo).get_device_information();
on_turn_off:
- lambda: id(PH_ezo).set_sleep();
- platform: ezo
address: 0x63 #99
accuracy_decimals: 2
unit_of_measurement: PH
state_class: "measurement"
update_interval: $updating
any help will be appreciated
