i have succesfully connected the Gateway with zigbee2mqtt.
If new devices are paired they show “not supported”.
Do you have any advice how to configure EZSP?
addon config:
mqtt:
base_topic: zigbee2mqtt
user: mqtt_user
password: mqtt_password
serial:
port: tcp://192.168.2.240:8888
adapter: ezsp
baudrate: 57600
greetings Schnabulator
Tinkerer
(aka DubhAd on GitHub)
2
What devices? What version of Zigbee2MQTT?
Thank you for your reply.
Radiator Valve
RGB bulb
Tested with both versions Zigbee2MQTT and Zigbee2MQTT Edge.
Tinkerer
4
Numbers matter. Edge could be 1.18 for all we know…
Zigbee2MSQTT EDGE v1.22.0-3
hijamie32
(Hijamie32)
6
did you ever get this to work as facing the same issue?
Cheers
Yes it work well so far.
IO switched to other radiator valves. The bulk workes fine.
Greetings
