EZVIZ C6N Service PTZ Not Working
Hi, I have integrated my Ezviz cam correctly into HA. Everything works except the PTZ function. I created a script that uses service: ezviz.ptz but it doesn’t work and it returns an error:
Logger: homeassistant
Source: components/ezviz/camera.py:281
First occurred: 08:31:04 (10 occurrences)
Last logged: 14:37:42
Error doing job: Task exception was never retrieved
  File "/usr/local/lib/python3.10/site-packages/pyezviz/client.py", line 603, in ptz_control
    req.raise_for_status()
  File "/usr/local/lib/python3.10/site-packages/requests/models.py", line 1021, in raise_for_status
    raise HTTPError(http_error_msg, response=self)
requests.exceptions.HTTPError: 400 Client Error: Bad Request for url: https://apiieu.ezvizlife.com/v3/devices/G84168513/ptzControl
  File "/usr/src/homeassistant/homeassistant/components/ezviz/camera.py", line 273, in perform_ptz
    self.coordinator.ezviz_client.ptz_control(
  File "/usr/local/lib/python3.10/site-packages/pyezviz/client.py", line 606, in ptz_control
    raise HTTPError from err
pyezviz.exceptions.HTTPError
  File "/usr/src/homeassistant/homeassistant/components/script/__init__.py", line 484, in _async_run
    return await self.script.async_run(script_vars, context)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 1524, in async_run
    await asyncio.shield(run.async_run())
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 409, in async_run
    await self._async_step(log_exceptions=False)
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 453, in _async_step
    self._handle_exception(
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 476, in _handle_exception
    raise exception
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 451, in _async_step
    await getattr(self, handler)()
  File "/usr/src/homeassistant/homeassistant/helpers/script.py", line 684, in _async_call_service_step
    await service_task
  File "/usr/src/homeassistant/homeassistant/core.py", line 1744, in async_call
    task.result()
  File "/usr/src/homeassistant/homeassistant/core.py", line 1781, in _execute_service
    await cast(Callable[[ServiceCall], Awaitable[None]], handler.job.target)(
  File "/usr/src/homeassistant/homeassistant/helpers/entity_platform.py", line 770, in handle_service
    await service.entity_service_call(
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 678, in entity_service_call
    future.result()  # pop exception if have
  File "/usr/src/homeassistant/homeassistant/helpers/entity.py", line 943, in async_request_call
    await coro
  File "/usr/src/homeassistant/homeassistant/helpers/service.py", line 715, in _handle_entity_call
    await result
  File "/usr/local/lib/python3.10/concurrent/futures/thread.py", line 58, in run
  File "/usr/src/homeassistant/homeassistant/components/ezviz/camera.py", line 281, in perform_ptz
    raise HTTPError("Cannot perform PTZ") from err
pyezviz.exceptions.HTTPError: Cannot perform PTZ
Do I make any mistakes?
Thanks!
