Hey
Getting this error when trying to install Ezviz via integration.
File "/usr/src/homeassistant/homeassistant/components/ezviz/config_flow.py", line 189, in async_step_user
return await self._validate_and_create_auth(user_input)
File "/usr/src/homeassistant/homeassistant/components/ezviz/config_flow.py", line 73, in _validate_and_create_auth
await self.hass.async_add_executor_job(_get_ezviz_client_instance, data)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/ezviz/config_flow.py", line 46, in _get_ezviz_client_instance
ezviz_client.login()
File "/usr/local/lib/python3.8/site-packages/pyezviz/client.py", line 509, in login
return self._login()
File "/usr/local/lib/python3.8/site-packages/pyezviz/client.py", line 124, in _login
self._token["session_id"] = str(json_result["loginSession"]["sessionId"])
KeyError: 'loginSession'
Whats wrong?
Username and password is correct, Checked, doublechecked and tripplechecked… =)
