Hi everyone,
I was using EZVIZ integration and all cameras allowing RTSP however at some point I stopped to see RTSP stream, in the integration I see all cameras but im not able to see the live camera anymore, any idea?
I’m not sure which camera models you have, but I had an experience with the Ezviz DB1C doorbell camera. I used it with Frigate via RTSP for years, until one day, after a firmware update, the RTSP feed just disappeared. After a long email exchange with Ezviz support, it turned out they had simply removed the RTSP feature from that model. I was so frustrated that I threw the camera in the trash and replaced it with a Reolink. I will never buy anything from Ezviz again.
Hi,i have ezviz cameras connected to go2rtc over rtsp.And I have it connected to the HA using a frigate card or you can use webrtc cart.
I have ezviz studio installed on my Windows PC, where I can search for cameras on my home network and adjust settings without having to log in to my ezviz account. So I don’t use the ezviz application or integration at all.
go2rtc can be installed as an integration or as an add-on. I recommend go2rtc, it is a lightweight application to which you can connect cameras from various manufacturers. and then it is no longer a problem to connect it with ha, frigate and the like.
I have cameras locally without internet access and go2rtc as a container on proxmox. Sometimes it happened that some camera would load with a delay, as if the system could not find it. So I tried to install this new integration WebRTC - Home Assistant When an application (ha, browser) tries to open a stream, it immediately connects to the stun server. The STUN server immediately returns the IP address. The browser does not have to wait for the completion of “Discovery” processes (such as mDNS), which sometimes cause problems with containers in Proxmox.
The connection immediately switches to direct data transfer, so no more “spinning wheels”.And another important thing, disable automatic update !!!
