Due to firmware upgrades or resets, the rtsp streams might not be available anymore. After a whole afternoon trying and swearing I found the solution, which is very well hidden.
Follow these steps:
Step 1: Ensure the camera and your phone are under the same network
Step 2: Open EZVIZ app,
Step 3: tap the profile icon on the top left > Settings > LAN Live View > Start Scanning
Step 4: Tap the camera you need to use, input the password, which usually is the 6-digit capital letters code on the white sticker of your camera
Step 5: Tap the gear-like icon on the top right > Local Server Settings > enable RTSP
I hope a prevented you from waisting an afternoon as well.
I got an Ezviz DP2C doorbell, no RTSP stream, the described above method is not working, nothing found on the LAN, although camera is streaming perfectly into it’s cloud-based app Ezviz PC Studio.
Since this did nothing for my setup (thanks a lot for the help anyway) I propose a brute-force workaround for EZVIZ RTSP (or any non RTSP-enabled device, any device, including doorbells)
It’s not the most “elegant” solution, but it works for any device regardless. The idea is to use an Android emulator as a bridge to broadcast the feed ourselves. You’ll need a PC to act as a “relay” with the following:
-Android Emulator: Use BlueStacks. To keep it lightweight, set the instance to “Low-end” (2 Cores, 2GB RAM) (which of course needs to stay active for this to work so those 2GB of RAM are the small price to pay to get your feed)
EZVIZ App (or whatever your AssBrand App): Install it inside the emulator and open your camera in full-screen mode.
ScreenStream: Install this excellent open-source app (screenstream.io) inside the emulator. It allows you to broadcast the Android screen/mic as an RTSP stream.
Now, the problem is that BlueStacks assigns an internal IP to the RTSP stream, making it inaccessible from your host PC or local network. To fix this, we need to use ADB (Android Debug Bridge) to forward our RTSP port:
Install Android SDK Platform-Tools on your PC to get the adb command.
Enable ADB connection in your BlueStacks instance settings.
Connect to the instance from your host PC (ports may vary, but usually): adb connect [127.0.0.1:5575](h t t p://127.0.0.1:5575/)
Forward the RTSP port from the emulator to your host (assuming ScreenStream is using 8554): adb forward tcp:8554 tcp:8554
Verify the connection (Windows PowerShell): Test-NetConnection [127.0.0.1](h t t p://127.0.0.1/) -p 8554
Now you have a functional RTSP feed accessible from your host and local network at rtsp://127.0.0.1:8554.
Troubleshooting tips:
If it fails, check your Windows Firewall settings for those ports.
If you need access from outside your home network, remember to set up Port Forwarding on your router.
It’s the definition of a workaround if I’ve ever seen one, but until EZVIZ (and any other pricky companies) stops being so restrictive, this is a solid way to get your feed. Hope this helps!
Good evening. I have a problem.
I have an EZVIZ EP3X Pro doorbell, which connects easily to both the Hikvision and Ezviz apps—it works flawlessly in both.
This doorbell's RTSP port is disabled by software. I think it's because if I connect to the doorbell's access point, ports 8000 and 554 work fine at 192.168.8.1.
But after the doorbell is initialized and connected to the app, the device receives an IP address from the router, and all ports become unavailable.
I was able to access the advanced settings through the app, but the password doesn't work. Does anyone know if there's a service password involved?
Thank you.
After trying several settings and getting nowhere, I finally solved the mystery without editing or changing any settings.
Steps:
1: Verify that RTSP is running
Try opening the camera address in VLC player, for example: rtsp://admin:[email protected]:554/h264
*YMTXTX = is your 6-digit code labeled on the camera
Add GENERIC CAMERA and enter the integration address: rtsp://admin:[email protected]:554/h264
Cool. This is very interesting; I’ll give it a try tomorrow. Could you tell me if it’s possible to add this to Frigate or go2rtc? I need it for identifying the face of the person ringing the doorbell. Thanks.
Glad the EP3x works. Any camera on the same EZVIZ account shows up on its own: add it in the EZVIZ app, then store its verification code under Configure → Verification codes and add another EZVIZ Cloud live card for it.
For Frigate, try 0.12.0-beta.1 (turn on beta versions for EZVIZ Cloud in HACS). Configure → Stream address for other apps gives each camera an address Frigate’s go2rtc can read. Don’t leave it on all the time or the battery won’t last: keep the camera off in Frigate and let an automation turn it on for a minute when the doorbell rings. The README has both snippets: GitHub - bvis/ezviz-cloud-hass: Live view, photos and clips of EZVIZ cameras through the EZVIZ cloud, for battery cameras and peepholes with no RTSP · GitHub. Expect a few seconds before the first picture while the camera wakes up. I don’t run Frigate myself, so tell me how it goes.
Not anymore. 0.13.0-beta.1 adds a second way to sign in: pick “EZVIZ app account” when you add the integration and it uses the login of Home Assistant’s built-in EZVIZ integration, so there’s no Open Platform app and no 120-day limit. You need the built-in EZVIZ integration set up with your EZVIZ account first.
If you already have it running, open EZVIZ Cloud, choose Reconfigure > EZVIZ app account and pick your account. Your verification codes, recordings and entities stay as they are. To get the beta, turn on beta versions for EZVIZ Cloud in the Marketplace (or HACS if you’re below 2026.11).
The live camera, photos, clips and the Frigate address work the same. Let me know if the EP3x behaves with it.
Update: this is in the stable 0.13.0 now, no need to turn on beta versions.
