Hi guys. I am really out of ideas. I even thought that my USB Stick is broken which is why I ordered a new one on Amazon only to find out that the other one has exactly the same problem.
It is some kind of driver fault, so the add on tries to restart the device a couple of times but then it stops which then fails to start the Z-wave integration. I tried it in different USB inputs in my Raspberry Pi , but its always the same issue.
Here is an excerpt of the logs I could find.
I set the hardware configuration to (device)
/dev/serial/by-id/usb-0658_0200-if00
Everything else I left untouched. It has worked before but then it suddenly stopped.
Full log is found here:
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/config.sh
[23:14:08] INFO: Both 'network_key' and 's0_legacy_key' are set and match. All ok.
[23:14:11] INFO: Virtual Machine not detected, enabling soft-reset
cont-init: info: /etc/cont-init.d/config.sh exited 0
cont-init: info: running /etc/cont-init.d/structure.sh
cont-init: info: /etc/cont-init.d/structure.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun zwave_js (no readiness notification)
s6-rc: info: service legacy-services successfully started
[23:14:12] INFO: Successfully send discovery information to Home Assistant.
2023-01-13T22:14:15.439Z DRIVER ███████╗ ██╗ ██╗ █████╗ ██╗ ██╗ ███████╗ ██╗ ███████╗
2023-01-13T22:14:15.448Z DRIVER version 10.3.0
2023-01-13T22:14:15.449Z DRIVER
2023-01-13T22:14:15.615Z CONFIG version 10.3.0
2023-01-13T22:14:17.041Z CNTRLR querying controller IDs...
2023-01-13T22:14:18.439Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-01-13T22:14:18.564Z DRIVER unexpected response, discarding...
2023-01-13T22:14:19.550Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-01-13T22:14:20.669Z DRIVER unexpected response, discarding...
2023-01-13T22:14:21.682Z DRIVER Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK
from the controller (ZW0200)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Drive
r.ts:3990:23)
at ZWaveController.identify (/usr/src/node_modules/zwave-js/src/lib/contro
ller/Controller.ts:713:33)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src
/lib/driver/Driver.ts:1208:26)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Dr
iver.ts:1015:16)
Error in driver ZWaveError: Failed to initialize the driver: ZWaveError: Timeout while waiting for an ACK from the controller (ZW0200)
at Driver.sendMessage (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:3990:23)
at ZWaveController.identify (/usr/src/node_modules/zwave-js/src/lib/controller/Controller.ts:713:33)
at Driver.initializeControllerAndNodes (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1208:26)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1015:16) (ZW0100)
at Immediate.<anonymous> (/usr/src/node_modules/zwave-js/src/lib/driver/Driver.ts:1032:6)
at processTicksAndRejections (node:internal/process/task_queues:96:5) {
code: 100,
context: undefined,
transactionSource: undefined
Shutting down
[22:14:21] WARNING: Halt add-on
s6-rc: info: service legacy-services: stopping
[22:14:21] INFO: Service restart after closing
s6-rc: info: service legacy-services successfully stopped
s6-rc: info: service legacy-cont-init: stopping
s6-rc: info: service legacy-cont-init successfully stopped
s6-rc: info: service fix-attrs: stopping
s6-rc: info: service fix-attrs successfully stopped
s6-rc: info: service s6rc-oneshot-runner: stopping
s6-rc: info: service s6rc-oneshot-runner successfully stopped
Please help because many devices at my house use the Zwave integration(Fibaro for instance). I really appreciate your help
