Its already on HACS
Apologies, my mistake/
Oh it needs to be added as a custom install?
How, havenāt tried that yet?
In HACS settings add a custom repository with the Github path for the project then it will appear as installable.
@juan11perez I updated deepstack face to v0.2 which allows use of an API key to secure deepstack. There is also an optional fast detect_only
mode.
Cheers
Super keen to give this a go, but donāt seem to be able to locate the noavx version of the Docker image. No doubt Iām missing something really simple.
Iām planning to run it on a Qnap Nas device.
Thanks for any input.
.N
If you use the correct docker run
command (in the deepstack docs) it will pull the image
Hi Robin,
Thanks for your reply.
Qnap has an app (Container Station) which is a GUI that integrates both LXC and Docker virtualization technologies. It provides the ability to search for an image, but also a dialog to Pull a particular image. Unfortunately the āImage Nameā field doesnāt allow you to use a colon as in deepstack:noavx
I will have to try doing it from the cmd line.
Nigel
Is anyone using multiple targets? Tried this but it didnāt work.
image_processing:
- platform: deepstack_object
ip_address: localhost
port: 5000
scan_interval: 20000
save_file_folder: /config/www/deepstack_person_images
target: person, truck
confidence: 80
source:
- entity_id: camera.front
I tried the same, but I ended up doing two instances of the image_processing.
I donāt think the other one is possible at the moment.
But the other way around works perfectly!
Not at home atm but I ended up doing this by editing the code very slightly.
In the initial config I still had target:person but in the code did a simple edit in the section which checked for prediction = target to add in AND prediction = ācarā. This was more a bandaid fix but enough for my purposes. Now either person or car will trigger the save file event and boxes drawn on both.
For me this helped identify when a car or person (or both) are in the image.
A better solution would be to pass in target as an array and go from there but this would need more code editing.
There is only a single target
per entity but you can configure multiple entities
Does this mean that the same image would need to be processed twice ie once to detect āpersonā and once for ātruckā.
Yes each entity will process the same image in this case. Alternatively you can use the image_processing.object_detected
event
Hi
Iām running the latest releaseHass.io under Ubuntu in a Docker environment. After setting up Deepstack based on the guide Iāve tried to restart HA but it gave me this error:
Platform error image_processing.deepstack_face - No module named ādeepstackā
Could you please help me correcting this error? Iām clueless.
hi rob, great work again. in your opinion is this better for person detection than tensorflow? I ran out of free images (5000) with amazon rekognition and moved to local tensorflow recently (NUC with i5 8th gen). please let me know. Thanks.
Well I wrote Deepstack integration for a reason In terms of performance there is not much difference. Deepstack easier to use IMO
