I created an app for exploring the config parameter for the deepstack object integration, created a thread here
Heyā¦ could you please export me node red code pleaseā¦ I only do mine in mode red as wellā¦
For starters; thanks a lot for this great integration, itās fun and easy to use. You obviously spent a lot of time developing it - to share that effort for free is really kind of you
I have a question: currently Iām using your tooling to detect whether neighborhood cats came into the house (we keep the door open, and they do that all the time to eat our catās food, bastards). When a cat is detected, I get a telegram notification.
For the next phase, I want to use the images of the various cats to create a new ml model, so I can recognize my cat from the others - that way I only get notifications for other cats.
Is there a way I can store the images in which deepstack detected a cat (or dog, as deepstack keeps calling my cat a dog) as-is? Iād like to keep the single ādeepstack_object_local_file_latest.jpgā setup so I can send that through telegram.
At any rate, thanks for your time, and best of luck
@SamKr you want save_timestamped_file: True
To recognise YOUR cat that is a classification problem, and you would want to deploy a custom model (possible in deepstack when they open source it)
Almost, Iād like those images, but without the red rectangle (because itād mess with the model).
Iām planning to use Microsoftās ML.NET model builder to get some experience with that as well
Hey @robmarkcole,
Iām still using your ātflite_server integrationā as custom component and it is so far working fine, how ever I want to save all the detected images in my save_file_folder folder with timestamp, currently it is only saving the latest detected picture, could you please help me get this on this component.
My configuration.yaml is as below
image_processing:
- platform: tflite_server
ip_address: 192.168.1.120
port: 5000
scan_interval: 15
save_file_folder: /config/www/
source:
- entity_id: camera.esp_camera
Component that will perform object detection via tensorflow-lite-rest-server
import datetime
import io
import json
import logging
import os
from datetime import timedelta
from typing import List, Tuple
import requests
from PIL import Image, ImageDraw
from homeassistant.util.pil import draw_box
import deepstack.core as ds
import homeassistant.helpers.config_validation as cv
import homeassistant.util.dt as dt_util
import voluptuous as vol
from homeassistant.components.image_processing import (
ATTR_CONFIDENCE,
CONF_ENTITY_ID,
CONF_NAME,
CONF_SOURCE,
DOMAIN,
PLATFORM_SCHEMA,
ImageProcessingEntity,
from homeassistant.const import (
ATTR_ENTITY_ID,
ATTR_NAME,
CONF_IP_ADDRESS,
CONF_PORT,
HTTP_BAD_REQUEST,
HTTP_OK,
HTTP_UNAUTHORIZED,
from homeassistant.core import split_entity_id
_LOGGER = logging.getLogger(__name__)
CONF_SAVE_FILE_FOLDER = "save_file_folder"
CONF_TARGET = "target"
DATETIME_FORMAT = "%Y-%m-%d %H:%M:%S"
DEFAULT_PORT = 5000
DEFAULT_TARGET = "person"
RED = (255, 0, 0)
SCAN_INTERVAL = timedelta(days=365) # NEVER SCAN.
PLATFORM_SCHEMA = PLATFORM_SCHEMA.extend(
vol.Required(CONF_IP_ADDRESS): cv.string,
vol.Optional(CONF_PORT, default=DEFAULT_PORT): cv.port,
vol.Optional(CONF_TARGET, default=DEFAULT_TARGET): cv.string,
vol.Optional(CONF_SAVE_FILE_FOLDER): cv.isdir,
def get_target(predictions: List, target: str):
Return only the info for the targets.
targets = []
for result in predictions:
if result["name"] == target:
targets.append(result)
return targets
def setup_platform(hass, config, add_devices, discovery_info=None):
"""Set up the classifier."""
save_file_folder = config.get(CONF_SAVE_FILE_FOLDER)
if save_file_folder:
save_file_folder = os.path.join(save_file_folder, "") # If no trailing / add it
entities = []
for camera in config[CONF_SOURCE]:
object_entity = ObjectDetectEntity(
config.get(CONF_IP_ADDRESS),
config.get(CONF_PORT),
config.get(CONF_TARGET),
config.get(ATTR_CONFIDENCE),
save_file_folder,
camera.get(CONF_ENTITY_ID),
camera.get(CONF_NAME),
entities.append(object_entity)
add_devices(entities)
class ObjectDetectEntity(ImageProcessingEntity):
"""Perform a face classification."""
def __init__(
self,
ip_address,
port,
target,
confidence,
save_file_folder,
camera_entity,
name=None,
"""Init with the API key and model id."""
super().__init__()
self._object_detection_url = f"http://{ip_address}:{port}/v1/object/detection"
self._target = target
self._confidence = confidence
self._camera = camera_entity
if name:
self._name = name
else:
camera_name = split_entity_id(camera_entity)[1]
self._name = "tflite_{}".format(camera_name)
self._state = None
self._targets = []
self._last_detection = None
self._save_file_folder = save_file_folder
def process_image(self, image):
"""Process an image."""
self._image_width, self._image_height = Image.open(
io.BytesIO(bytearray(image))
).size
self._state = None
self._targets = []
payload = {"image": image}
response = requests.post(self._object_detection_url, files=payload)
if not response.status_code == HTTP_OK:
return
predictions = response.json()
self._targets = get_target(predictions["objects"], self._target)
self._state = len(self._targets)
if hasattr(self, "_save_file_folder") and self._state > 0:
self.save_image(image, self._targets, self._target, self._save_file_folder)
@property
def camera_entity(self):
"""Return camera entity id from process pictures."""
return self._camera
@property
def state(self):
"""Return the state of the entity."""
return self._state
@property
def name(self):
"""Return the name of the sensor."""
return self._name
@property
def unit_of_measurement(self):
"""Return the unit of measurement."""
target = self._target
if self._state != None and self._state > 1:
target += "s"
return target
@property
def device_state_attributes(self):
"""Return device specific state attributes."""
attr = {}
if self._targets:
attr["targets"] = [result["score"] for result in self._targets]
if self._last_detection:
attr["last_{}_detection".format(self._target)] = self._last_detection
return attr
def save_image(self, image, predictions, target, directory):
"""Save a timestamped image with bounding boxes around targets."""
img = Image.open(io.BytesIO(bytearray(image))).convert("RGB")
draw = ImageDraw.Draw(img)
for prediction in predictions:
prediction_confidence = ds.format_confidence(prediction["score"])
if (
prediction["name"] in target
and prediction_confidence >= self._confidence
draw_box(
draw,
prediction['box'],
self._image_width,
self._image_height,
text=str(prediction_confidence),
color=RED,
latest_save_path = directory + "{}_latest_{}.jpg".format(self._name, target[0])
img.save(latest_save_path)
@SamKr I released v3.4 just for you , let me know how you get on.
@Hitesh_Singh I think I archived that integration, please use deepstack-object
Hey @robmarkcole, thanks for all the hard work with these two great custom components. I managed to get both Object and Face detection running smoothly and absolutely love it. My question to you is, can we install/teach new models?
I specifically have an issue with snakes and would like to have my driveway CCTV cam alert me if any snakes come in from under the gate; is that something that is possible to integrate with the current Deepstack setup?
Looking forward to hearing from you and thanks once again for al the effort with this integration!
Working on itā¦
@robmarkcole Iām using a Raspberry Pi 4 4GB model, and deepstack-object will have performance issue in it, which is why was asking help on tflite_server integration. as it runs fine on a raspberry.
@Hitesh_Singh use https://github.com/robmarkcole/tensorflow-lite-rest-server runs on rpi and I just added face detection to it too! works with deepstack integrations
Thanks for this, working great. Is it possible have an option to export another image of the frames only as a transparent PNG (same size as the frame size) so I can overlay it over an image ?
Can you give some example python code?
can you show me what you did to resolve this? I am having the same error.
Thanks much @robmarkcole
Iām not using it, and the curl results are giving me correct results, How ever in my HA Iām still not getting the counts
My configuration.yaml is as below, what Iām doing wrong !!
image_processing:
- platform: deepstack_object
port: 5000
source:
I see here you have mentioned " This API can be used as a drop in replacement for deepstack object detection and deepstack face detection (configuring detect_only: True
) in Home Assistant."
is there any detect_only: True setting that I need to change somewhere !! Could you please help.
Is there a docker version of the tensorflow-lite-rest-server ? Thank you in advance for your answers
[{"id":"f47ff4fa.790eb8","type":"tab","label":"Flow 2","disabled":false,"info":""},{"id":"d6db80b9.75fda","type":"server-state-changed","z":"f47ff4fa.790eb8","name":"cat motion","server":"7dbb919d.bdcf9","version":1,"exposeToHomeAssistant":false,"haConfig":[{"property":"name","value":""},{"property":"icon","value":""}],"entityidfilter":"binary_sensor.cat_pir_alarm","entityidfiltertype":"exact","outputinitially":false,"state_type":"str","haltifstate":"on","halt_if_type":"str","halt_if_compare":"is","outputs":2,"output_only_on_state_change":true,"x":80,"y":140,"wires":[["5f32488e.7205e8"],[]]},{"id":"ca1f37d1.ac86a8","type":"delay","z":"f47ff4fa.790eb8","name":"","pauseType":"delay","timeout":"1","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":500,"y":140,"wires":[["d3c5ef9e.2ee75"]]},{"id":"d3c5ef9e.2ee75","type":"api-call-service","z":"f47ff4fa.790eb8","name":"Deepstack Cat Scan","server":"7dbb919d.bdcf9","version":1,"debugenabled":false,"service_domain":"image_processing","service":"scan","entityId":"image_processing.deepstack_object_deepstack_cat","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":280,"y":240,"wires":[["18c4fd29.4d73a3"]]},{"id":"5f32488e.7205e8","type":"api-call-service","z":"f47ff4fa.790eb8","name":"Grab cat Image","server":"7dbb919d.bdcf9","version":1,"debugenabled":false,"service_domain":"shell_command","service":"cat_snapshot","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":300,"y":140,"wires":[["ca1f37d1.ac86a8"]]},{"id":"18c4fd29.4d73a3","type":"delay","z":"f47ff4fa.790eb8","name":"","pauseType":"delay","timeout":"4","timeoutUnits":"seconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":480,"y":240,"wires":[["86efdf82.aba3d"]]},{"id":"86efdf82.aba3d","type":"api-current-state","z":"f47ff4fa.790eb8","name":"Cat Check","server":"7dbb919d.bdcf9","version":1,"outputs":2,"halt_if":"0","halt_if_type":"num","halt_if_compare":"gt","override_topic":false,"entity_id":"image_processing.deepstack_object_deepstack_cat","state_type":"str","state_location":"","override_payload":"none","entity_location":"","override_data":"none","blockInputOverrides":false,"x":710,"y":240,"wires":[["a4ade475.6865e8"],[]]},{"id":"a4ade475.6865e8","type":"api-call-service","z":"f47ff4fa.790eb8","name":"Telegram cat photo","server":"7dbb919d.bdcf9","version":1,"debugenabled":false,"service_domain":"shell_command","service":"cat_msg","entityId":"","data":"","dataType":"json","mergecontext":"","output_location":"","output_location_type":"none","mustacheAltTags":false,"x":970,"y":240,"wires":[[]]},{"id":"7dbb919d.bdcf9","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":false,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true,"cacheJson":false}]
camera:
- platform: local_file
file_path: /config/www/deepstack_cat.jpg
file_path: /config/www/snapshots/deepstack_object_deepstack_cat_latest.jpg
image_processing:
ip_address: localhost
port: 5000
# api_key: mysecretkey
save_file_folder: /config/www/snapshots/
save_timestamped_file: false
# roi_x_min: 0.35
roi_x_max: 0.8
#roi_y_min: 0.4
roi_y_max: 0.8
targets:
- cat
source:
- entity_id: camera.deepstack_cat
shell_command:
cat_snapshot: '(curl -s -X GET http://<ip of my hikvision picture stream>/ISAPI/Streaming/channels/2/picture > deepstack_cat.jpg && mv deepstack_cat.jpg www )'
cat_msg: '(curl -s -X POST "https://api.telegram.org/bot<your telegram bot token>/sendPhoto" -F chat_id=<cat chat id> -F photo="@/config/www/snapshots/deepstack_object_deepstack_cat_latest.jpg" -F caption="Cat Detected")'
@Hitesh_Singh detect_only: True
is a required parameter for the deepstack face integration when using tensorflow-lite.
@alpat59 no docker yet but that is a nice idea, should be possible
