I had this problem with a sensor template once from copying and pasting an example with the degree symbol. It wasn’t obvious to me at the time that the degree symbol was what was causing the issue.
One way around this is to get a copy of SublimeText, which has a “Save with Encoding” option that will allow you to save in UTF-8 format. This is helpful if you can’t figure out what character is causing the issue.
17-01-23 22:43:02 homeassistant.bootstrap: Setting up notify
17-01-23 22:43:02 homeassistant.bootstrap: Error during setup of component notify
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/bootstrap.py", line 151, in _async_setup_component
None, component.setup, hass, config)
File "/usr/lib/python3.4/asyncio/futures.py", line 388, in __iter__
yield self # This tells Task to wait for completion.
File "/usr/lib/python3.4/asyncio/tasks.py", line 286, in _wakeup
value = future.result()
File "/usr/lib/python3.4/asyncio/futures.py", line 277, in result
raise self._exception
File "/usr/lib/python3.4/concurrent/futures/thread.py", line 54, in run
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/__init__.py", line 143, in setup
if not setup_notify_platform(platform, p_config):
File "/srv/homeassistant/lib/python3.4/site-packages/homeassistant/components/notify/__init__.py", line 89, in setup_notify_platform
hass, p_config, discovery_info)
TypeError: get_service() takes 2 positional arguments but 3 were given
17-01-23 22:43:02 homeassistant.core: Bus:Handling <Event call_service[L]: service=create, service_data=notification_id=invalid_config, message=The following components and platforms could not be set up:
* [notify](https://home-assistant.io/components/notify/)
Please check your config, title=Invalid config, domain=persistent_notification, service_call_id=3051388208-1>
Is there an é in your file anywhere? Replacing it with e might fix it?
(sorry for the zombie topic resurrection, I just changed a ø from an awesome Norwegian programmer that was causing a 'utf-8' codec can't decode byte 0xf8 error on my English setup)
