Factory Reset Green
I tried to setup my green for the first time and apparently I disconnected it too fast, because it refused to start up. (Something about a docker download). So now I am trying to do a factory reset to start the process over again. I have followed the factory reset instructions to the letter, and it just doesn’t seem to ever reinstall. I successfully flashed the version of green to a SD card, but I never get the rapidly flashing lights that the instructions say that I should get, and it never turns the lights off to show that the install is complete.
Anyone ever find a solution to this?
Have you found solution to this?
I have green and it is not starting. Reset not working, MicroSD method not workings (no fast blinking).
I have a green. It’s been working well for a few months. I attempted to perform upgrades to core, etc. checked storage and it was 100% full. I have a very basic setup, 2 lights on timer and other zigbee stuff. No apps or anything.
Rebooted, won’t communicate. Attempted factory reset with button. Can’t communicate via default address or the address I had set previously.
I now have a brick. What to do?
Hi, I followed the instructions but it does not reset. Then i tried to reset by SD card but balenaEtcher is telling me the file from Gitbub “error opening source” error:(0, h.requestMetadata) is not a function.
seems the file is not correct.
Any idea?
Found a solution: run balenaEtcher in “Admin” or Win 7 mode, then it works
Does not work for me,I can login to home assistant greeen but there are no settings available so can’t do much I reached out to nabu casa and all they recommend was to come on here.
You need to provide more information.
I don’t know what more I can say I do a factory reset exactly as specified but it only goes to the login screen not the create account
When I login it puts home assistant on but they’re are no settings available in the sidebar so it’s useless without them
I’ve big troubles with resetting my Green.
A bit background:
I ran out of storage space, so I attached a USB-stick. I made backups, I moved disk data, but unfortunately, the HA became much too slow. My mistake, I should have checked better the requirements, and buy a fast SSD instead…
Anyway: I first tried to move the data back to the eMMS. It still fits,
I made a backup again, tried diskdata wipe (didn’t work), then tried to reset the Green using the small black button.
I had to do a hard shut down (12 second press).
Power off, power on again, while pressing the button => Yellow light blinks steady.
Release the button => yellow and green start blinking.
But after that, nothing happens.
When I use a display on the HA-Green, it says already for hours:
“Waiting for the Home Assistant CLI to be ready…”
ping homeassistant.local -t gives results, so Green is alive.
For the rest, nothing is happening…
What can I do?
I hope you can help, I’m getting a bit desparate,
brgds, Leon
