Factory Reset Home Assistant Green, Now Can't Connect
I’m frustrated. I had some serious issues with HA - ZHA quit working, then all my automations vanished and new ones wouldn’t save (and blueprints wouldn’t load) so I factory reset Home Assistant Green, held down the button until is tuned on solid, then waited a while. According to my router (It’s showing as a device on the router, connected by hardware LAN), it then pulled down about 2.6 GB of data, but when I go to connect I get a site refused to connect 192.168.50.62 refused to connect. The iPhone app gives a little more detail "Could not connect to the server. NSURLErrorDomain code -1004 URL http://192.168.50.62/dashboard-condo/0 Any help is appreciated. I can’t live without HA.
As per the docs, installing might take quite a while. If that time has passed, then step one would be to connect a monitor to see if it got an ip address. Maybe it got another one? And if you did not restore a backup yet, the dashboard you are linking to isn’t there yet. try just the ip and port.
Waiting for Home Assistant CLI to be ready
