After following the instructions at the link below for a Factory Rest.
Nothing happens lights blink as normal.
Can you please explain the steps i need to take as if you are talking to a Newbie. Also can you give download links with step by step instructions to a Newbie.
The only important point that is not mentioned is that your HA Green must be connected to the internet when following those instructions. The pictures show a network cable connected to the box but this is not mentioned in the text.
Factory Reset Home Assistant green?
Hello, I just get the new home assistant green and follow the steps to install the hacs but when I copy & past it on terminal & ssh I get a message saying : No such file or directory.
Ive tried so many different things but I think the best way is to start all over from start but I can’t factory reset home assistant green either…
Can you help me please?
