Fade Light Automation
Hi All,
As a HA/yaml novice and many headaches, I’ve managed to get my first automation working using an Aqara P1 motion sensor, analog RGBCC (5in1 leds), and ESPThings Analoge LED controller.
I have these instaled in my kitchen running a slow rainbow effect, and when motion is detected the effect stops and the leds go to full power and brightness to provide light to work on the kitchen worktops.
This works reasonably well for what I wish to do, but once motion is detected the leds turn to white like flicking a light switch On. I’d like them to fade On (say over 10 seconds).
I’ve tried using transition, but this doesn’t work.
I know I can add many more service call for light turn On at different increments of percentages or pwm power (call service light turn on 5%, call another service light turn on 10% and so on), but I was wondering if there was a better way rather then having like 20 service calls in one automation?
Can someone point me in the right direction for reading how to do this in a better way?
Heres the esp leds sketch;
esphome:
esp32:
  board: esp32dev
  framework:
    type: arduino
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: "Guess"
ota:
  password: "Guess"
wifi:
  ssid: !secret wifi_ssid
  ap:
    ssid: "Kitchen-Colour-Leds-1"
    password: "Guess"
captive_portal:
  - platform: wifi_signal
    name: "WiFi Signal $devicename"
    update_interval: 60s
output:
  - platform: ledc
    pin: 26
    frequency: 25000Hz
  - platform: ledc
    pin: 18
    frequency: 25000Hz
  - platform: ledc
    pin: 19
    frequency: 25000Hz
  - platform: ledc
    pin: 23
    frequency: 25000Hz
  - platform: ledc
    pin: 05
    frequency: 25000Hz
light:
  - platform: rgbww
    name: "kitchen colour leds 1"
    warm_white: ledc_ww
    cold_white: ledc_cw
    red: ledc_r
    green: ledc_g
    blue: ledc_b
    cold_white_color_temperature: 5000K
    warm_white_color_temperature: 3000K
    color_interlock: true
    effects:
      - lambda:
          update_interval: 16s
          lambda: |-
            static int state = 0;
            auto call = id(kcl2).turn_on();
            call.set_transition_length(15000);
            if (state == 0) {
              call.set_rgb(1.0, 0.0, 0.0);
            } else if (state == 1) {
              call.set_rgb(1.0, 0.5, 0.0);
            } else if (state == 2) {
              call.set_rgb(1.0, 1.0, 0.0);
            } else if (state == 3) {
              call.set_rgb(0.5, 1.0, 0.0);
            } else if (state == 4) {
              call.set_rgb(0.0, 1.0, 0.0);
            } else if (state == 5) {
              call.set_rgb(0.0, 1.0, 0.5);
            } else if (state == 6) {
              call.set_rgb(0.0, 1.0, 1.0);
            } else if (state == 7) {
              call.set_rgb(0.0, 0.5, 1.0);
            } else if (state == 8) {
              call.set_rgb(0.0, 0.0, 1.0);
            } else if (state == 9) {
              call.set_rgb(0.5, 0.0, 1.0);
            } else if (state == 10) {
              call.set_rgb(1.0, 0.0, 1.0);
            } else if (state == 11) {
              call.set_rgb(1.0, 0.0, 0.5);
            call.perform();
            state++;
            if (state == 12)
              state = 0;
      - strobe:
      - strobe:
          name: Strobe Effect With Custom Values
          colors:
            - state: true
              brightness: 100%
              red: 100%
              green: 90%
              blue: 0%
              duration: 500ms
            - state: false
              duration: 250ms
            - state: true
              brightness: 100%
              red: 0%
              green: 100%
              blue: 0%
              duration: 500ms
      - flicker:
      - flicker:
          name: Flicker Effect With Custom Values
          alpha: 95%
          intensity: 10.5%
      - random:
      - random:
          name: Random Effect With Custom Values
          transition_length: 5s
          update_interval: 7s
      - pulse:
      - pulse:
          transition_length: 0.5s
          update_interval: 0.5s
      - pulse:
          # transition_length: 1s      # defaults to 1s
          update_interval: 2s
Heres the automations yaml;
alias: kitchen leds catch
description: ""
  - type: motion
    platform: device
    device_id: 0a0d2e74956722bc0f62949fbab52519
    entity_id: binary_sensor.kitchen_pir
    domain: binary_sensor
condition: []
  - service: scene.create
      scene_id: leds_before_motion_1
      snapshot_entities: light.kitchen_colour_leds_1
  - service: light.turn_on
      kelvin: 6500
      effect: None
      brightness: 255
      entity_id: light.kitchen_colour_leds_1
mode: restart
alias: kitchen leds reload
description: ""
  - type: no_motion
    platform: device
condition: []
  - service: scene.turn_on
    data: {}
      entity_id: scene.leds_before_motion_1
mode: restart
