Just knocked this up this script and it may be useful to some people. It allows the following:
- The fading on or off of any lights that can do so
- Customizable transition times
- Customizable delays until the fade begins
- Custom start positions IE do you want your lights to transition from a set value
Feedback is welcome
sequence:
- if:
- condition: template
value_template: "\"{{ custom_start }}\""
alias: A custom light starting point was selected
then:
- target:
entity_id: "{{ light_selection }}"
rgb_color: "{{ color }}"
brightness_pct: "{{ brightness_start }}"
alias: Turn the Lights to their starting brightness and color
action: light.turn_on
alias: If a custom light starting value was selected, set that value
- delay: "{{ delay }}"
alias: The delay until the light starts fading on
- action: light.turn_on
metadata: {}
transition: "{{ transition }}"
brightness_pct: "{{ brightness_finish }}"
alias: Fade the Lights to their selected brightness
fields:
light_selection:
name: 💡 Light Selection
description: Lights to fade on
selector:
entity:
multiple: true
domain: light
required: true
color:
selector:
color_rgb: {}
description: What color should the light fade to?
default:
- 0
- 0
- 0
required: true
custom_start:
selector:
boolean: {}
name: 🚀 Custom Start
description: Customize your lights starting point? (Required for Brightness Start)
required: true
default: false
brightness_start:
selector:
number:
min: 0
max: 100
step: 1
name: 🌙 Brightness Start
description: what brightness should it start at?
required: true
default: 0
brightness_finish:
selector:
number:
min: 0
max: 100
name: ☀️ Brightness Finish
description: what brightness should it reach?
required: true
default: 90
transition:
selector:
number:
min: 5
max: 180
step: 1
name: 🔄 Transition
description: How long should the fade on take? (in seconds)
default: 130
required: true
delay:
selector:
number:
min: 0
max: 30
step: 1
description: The delay until the light starts fading on (in seconds)
required: true
default: 2
mode: restart
alias: Fade on the Selected Lights
description: Fade on the lights you wish with their respective brightness and color options
icon: mdi:weather-sunset-up
