AFAIK unlike with lights, for volume we do not have a transition time within HomeAssistant. So that means, you will have to do it manually.
I use this in my AlarmClock to slowly fade my speakers volume higher:
[{"id":"7333079d.8b6648","type":"traffic","z":"1de400c0.5ce76f","name":"Turn Up Volume","property_allow":"payload","filter_allow":"start","ignore_case_allow":false,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"snooze","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":false,"differ":false,"x":640,"y":1240,"wires":[["f33856e4.d23368"]]},{"id":"2a6d1f1f.3c584","type":"inject","z":"1de400c0.5ce76f","name":"Volume ---->","topic":"","payload":"volume","payloadType":"flow","repeat":"40","crontab":"","once":false,"onceDelay":0.1,"x":260,"y":1240,"wires":[["7333079d.8b6648"]]},{"id":"5662301f.21a64","type":"function","z":"1de400c0.5ce76f","name":"Set Volume","func":"newmsg = {};\nvar volume = flow.get(\"volume\");\n\nnewmsg.payload = { data: { \"volume_level\":volume} }\n\nreturn newmsg;","outputs":1,"noerr":0,"x":950,"y":1240,"wires":[["f29cf51d.352b18"]]},{"id":"f29cf51d.352b18","type":"api-call-service","z":"1de400c0.5ce76f","name":"Bett","server":"2fba4297.e4145e","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.snapcast_schlafzimmer","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1110,"y":1240,"wires":[["151ef3c1.df7b0c"]]},{"id":"583af9fa.30a278","type":"function","z":"1de400c0.5ce76f","name":"Increment Volume","func":"var volume = flow.get('volume')||0;\n\nif (volume < 0.5) {\n volume = volume + 0.01;\n flow.set(\"volume\", volume);\n \n newmsg = {\"payload\":\"looping\"}\n return newmsg;\n}\nelse {\n newmsg = {\"payload\":\"done\"};\n return newmsg;\n}","outputs":1,"noerr":0,"x":1590,"y":1240,"wires":[[]]},{"id":"4baf3e74.26576","type":"function","z":"1de400c0.5ce76f","name":"Set Volume","func":"newmsg = {};\nvar volume1 = flow.get(\"volume1\");\n\nnewmsg.payload = { data: { \"volume_level\":volume1} }\n\nreturn newmsg;","outputs":1,"noerr":0,"x":950,"y":1320,"wires":[["558130a3.34ebf"]]},{"id":"558130a3.34ebf","type":"api-call-service","z":"1de400c0.5ce76f","name":"TV","server":"2fba4297.e4145e","version":1,"debugenabled":false,"service_domain":"media_player","service":"volume_set","entityId":"media_player.snapcast_schlafzimmer_tv","data":"","dataType":"json","mergecontext":"","output_location":"payload","output_location_type":"msg","mustacheAltTags":false,"x":1110,"y":1320,"wires":[["2cf38eb7.931382"]]},{"id":"6ccf26e6.557f38","type":"function","z":"1de400c0.5ce76f","name":"Increment Volume1","func":"var volume1 = flow.get('volume1')||0;\n\nif (volume1 < 0.5) {\n volume1 = volume1 + 0.01;\n flow.set(\"volume1\", volume1);\n \n newmsg = {\"payload\":\"looping\"}\n return newmsg;\n}\nelse {\n newmsg = {\"payload\":\"done\"};\n return newmsg;\n}","outputs":1,"noerr":0,"x":1590,"y":1320,"wires":[[]]},{"id":"97e9815d.b72dc","type":"inject","z":"1de400c0.5ce76f","name":"Volume1 ---->","topic":"","payload":"volume1","payloadType":"flow","repeat":"60","crontab":"","once":false,"onceDelay":0.1,"x":260,"y":1320,"wires":[["628d4533.f4b12c"]]},{"id":"628d4533.f4b12c","type":"traffic","z":"1de400c0.5ce76f","name":"Turn Up Volume","property_allow":"payload","filter_allow":"start","ignore_case_allow":true,"negate_allow":false,"send_allow":false,"property_stop":"payload","filter_stop":"snooze","ignore_case_stop":false,"negate_stop":false,"send_stop":false,"default_start":false,"differ":false,"x":640,"y":1320,"wires":[["5c7aa8a0.347508"]]},{"id":"151ef3c1.df7b0c","type":"api-current-state","z":"1de400c0.5ce76f","name":"Loudness","server":"2fba4297.e4145e","version":1,"outputs":1,"halt_if":"","halt_if_type":"str","halt_if_compare":"is","override_topic":true,"entity_id":"media_player.snapcast_schlafzimmer","state_type":"num","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1300,"y":1240,"wires":[["f1e415fc.fd7d18"]]},{"id":"2cf38eb7.931382","type":"api-current-state","z":"1de400c0.5ce76f","name":"Loudness","server":"2fba4297.e4145e","version":1,"outputs":1,"halt_if":"","halt_if_type":"num","halt_if_compare":"is","override_topic":true,"entity_id":"media_player.snapcast_schlafzimmer_tv","state_type":"num","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":1300,"y":1320,"wires":[["462327ac.3031d8"]]},{"id":"f33856e4.d23368","type":"api-current-state","z":"1de400c0.5ce76f","name":"Spotify?","server":"2fba4297.e4145e","version":1,"outputs":2,"halt_if":"playing,unavailable","halt_if_type":"str","halt_if_compare":"does_not_include","override_topic":true,"entity_id":"media_player.spotify","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":800,"y":1240,"wires":[[],["5662301f.21a64"]]},{"id":"5c7aa8a0.347508","type":"api-current-state","z":"1de400c0.5ce76f","name":"Spotify?","server":"2fba4297.e4145e","version":1,"outputs":2,"halt_if":"playing,unavailable","halt_if_type":"str","halt_if_compare":"does_not_include","override_topic":true,"entity_id":"media_player.spotify","state_type":"str","state_location":"payload","override_payload":"msg","entity_location":"data","override_data":"msg","blockInputOverrides":false,"x":800,"y":1320,"wires":[[],["4baf3e74.26576"]]},{"id":"f1e415fc.fd7d18","type":"switch","z":"1de400c0.5ce76f","name":"","property":"data.attributes.volume_level","propertyType":"msg","rules":[{"t":"lte","v":"0.5","vt":"num"},{"t":"gte","v":"0.5","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1430,"y":1240,"wires":[["583af9fa.30a278"],[]]},{"id":"462327ac.3031d8","type":"switch","z":"1de400c0.5ce76f","name":"","property":"data.attributes.volume_level","propertyType":"msg","rules":[{"t":"lte","v":"0.5","vt":"num"},{"t":"gte","v":"0.5","vt":"str"}],"checkall":"true","repair":false,"outputs":2,"x":1430,"y":1320,"wires":[["6ccf26e6.557f38"],[]]},{"id":"2fba4297.e4145e","type":"server","z":"","name":"Home Assistant","legacy":false,"addon":true,"rejectUnauthorizedCerts":true,"ha_boolean":"y|yes|true|on|home|open","connectionDelay":true}]
Basically what i do there:
First i define a variable with the volume. The Volume will then be incremented up based on a repeating timer (i.e.: every 20sec). I believe in the meantime you can also just call the volume_up service that didnt exist in the past. That should make it even easier.
