How to create a Blueprint to sync Ecobee and Faikout to control my Daiken.
Hi, I am close but would like a professional to help me cross the finish line. Looking at the RevK documentation, and your post, that there should be a way to use an Ecobee thermostat as the Master tstat and Fsikout just as a slave. Ecobee has all the automation I would need, and Home Assistant can control Ecobee as needed (window open etc).
Do you know anyone (or you?) that I could hire to build a HA Bkueprint that simply enters the ecobee device, room temperature device (ecobee sensor or anything else like zwave temp sensor), and the Faikout device and with just those 3 pieces can produce a predictable automation to allow Ecobee to work as a normal thermostat controlling my Daiken furnace?
I have 4 Faikout and the ecobees with just 24v power installed and ready. My efforts at a HA automation have come close, but still many efforts. I’d like to hire a pro, I’m just a regular guy. Thanks, whatsapp 360-961-0222, David
Who are you talking to?
And don't post your phone number or whatever that personal info is.
Are you having problems integrating the
Ecobee, Daikin, and Faikout integrations, automating the resulting sensors and controls, trying to reinvent climate controls or what?
There are many threads already here in the forums on these issues. Just hit the search button for Daikin.
This was recently discussed in another thread. Maybe you meant to post in that existing thread and accidentally started a new one. In which case a friendly moderator may oblige moving it.
