21-01-21 11:12:47 WARNING (MainThread) [supervisor.api.proxy] Unknown Home Assistant API access!
21-01-21 11:12:52 INFO (SyncWorker_2) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-samba with version 9.3.0
21-01-21 11:12:52 INFO (MainThread) [supervisor.addons.addon] Restore config for addon core_deconz
21-01-21 11:12:52 INFO (SyncWorker_0) [supervisor.docker.interface] Stopping addon_core_deconz application
21-01-21 11:13:07 INFO (SyncWorker_0) [supervisor.docker.interface] Cleaning addon_core_deconz application
21-01-21 11:13:07 INFO (MainThread) [supervisor.addons.addon] Restoring data for addon core_deconz
21-01-21 11:13:07 INFO (MainThread) [supervisor.addons.addon] Finished restore for add-on core_deconz
21-01-21 11:13:07 INFO (SyncWorker_0) [supervisor.docker.interface] Starting homeassistant
21-01-21 11:13:07 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is ready
21-01-21 11:14:16 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API token
21-01-21 11:16:19 INFO (SyncWorker_0) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-deconz with version 6.6.2
21-01-21 11:16:43 INFO (SyncWorker_1) [supervisor.docker.interface] Stopping addon_core_deconz application
21-01-21 11:17:08 INFO (SyncWorker_1) [supervisor.docker.interface] Cleaning addon_core_deconz application
21-01-21 11:17:23 INFO (SyncWorker_1) [supervisor.docker.addon] Starting Docker add-on homeassistant/aarch64-addon-deconz with version 6.6.2
21-01-21 11:17:57 WARNING (MainThread) [supervisor.api.proxy] Unknown Home Assistant API access!
**21-01-21 11:17:59 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config: **
**21-01-21 11:18:49 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config: **
**21-01-21 11:19:25 ERROR (MainThread) [supervisor.homeassistant.api] Error on call http://172.30.32.1:8123/api/config:**
21-01-21 11:20:43 INFO (MainThread) [supervisor.homeassistant.core] Detect a running Home Assistant instance
21-01-21 11:20:43 INFO (MainThread) [supervisor.snapshots] Partial-Restore a41653c1 done
**21-01-21 11:23:07 WARNING (MainThread) [supervisor.api.proxy] Unknown Home Assistant API access!**
**21-01-21 11:28:17 WARNING (MainThread) [supervisor.api.proxy] Unknown Home Assistant API access!**
I get these errors after taking a snapshot of my SD card and loading it on my USB stick. It ran without problems on SD, but it seems DECONZ (conbee2) is having problems.
I have my conbee2 in an extension cable and it is plugged into a usb2 stick as it should. I use the long device path to the USB connector that I find under hardware in the supervisor
