Hi, I’m trying to help a friend to set ports on fritzbox as the image, i.e. 8123 to 8123, external desired 443 but external assigned 8123, I have the same settings and I can access with duckdns and also have alexa integration with haaska working, with his router (fritzbox 7590) he can’t set the external assigned port to 8123,the router set 443 and the field is not editable, how can he solve? I have 7.01 firmware but he has 7.12
I have no problems because my settings are the same as the image, my friend can’t edit the lower fields, the router set always 443 but for alexa integration to work he needs 8123 external assigned, I don’t remeber hiw I managed to have those settings so we were wondering if it could be a firmware modem problem
after two days of trying a lot of probabilities, finally i have remote access from cellular network, and that’s the problem, because that is the only access i have from the application on my phones, if i change to wifi i lose connction or i have to browse the “httpS://my.ip.address:8123” to access.
this is my router configuration after port forwarging.
The Hassio configuration is the correct internal 8123 external door 8123
But when I create the https server configuration with internal port 8123 and external port 443 he still takes 8123
