I have a kincony 32 relay board with a MQTT integration.
I am able to control the relay (on/off) but in home assistant the status stay “unknown”
I spend many hours in tries, read the seller and HA docs and forum but I still stuck. I found people that had the same trouble but apparently without answer
What I have
The yaml configuration gave by the supplier is below
mqtt:
switch:
- name: 'KC868-32_output-1'
unique_id: a8s-kcs-output-1
state_topic: 'KC868_A32/1234/STATE'
command_topic: 'KC868_A32/1234/SET'
payload_on: '{"output1":{"value":true}}'
payload_off: '{"output1":{"value":false}}'
value_template: "{{ value_json.output1.value }}"
state_on: 1
state_off: 0
What works:
The output is physicaly set to ON or OFF on the real board
What fail:
The status in home asistant still “unknown”
In home assistant logs I get an error:
Template variable error: 'value_json' is undefined when rendering '{{ value_json.output1.value }}
Error parsing value: 'value_json' is undefined (value: {"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},.....
On the MQTT server I see the command and the response in the goot topics (SET or STATE)
The full response is below
{"input1":{"value":false},"input2":{"value":false},"input3":{"value":false},"input4":{"value":false},"input5":{"value":false},"input6":{"value":false},"input7":{"value":false},"input8":{"value":false},"input9":{"value":false},"input10":{"value":false},"input11":{"value":false},"input12":{"value":false},"input13":{"value":false},"input14":{"value":false},"input15":{"value":false},"input16":{"value":false},"input17":{"value":false},"input18":{"value":false},"input19":{"value":false},"input20":{"value":false},"input21":{"value":false},"input22":{"value":false},"input23":{"value":false},"input24":{"value":false},"input25":{"value":false},"input26":{"value":false},"input27":{"value":false},"input28":{"value":false},"input29":{"value":false},"input30":{"value":false},"input31":{"value":false},"input32":{"value":false},"output1":{"value":false},"output2":{"value":false},"output3":{"value":false},"output4":{"value":false},"output5":{"value":false},"output6":{"value":false},"output7":{"value":false},"output8":{"value":false},"output9":{"value":false},"output10":{"value":false},"output11":{"value":false},"output12":{"value":false},"output13":{"value":false},"output14":{"value":false},"output15":{"value":false},"output16":{"value":false},"output17":{"value":false},"output18":{"value":false},"output19":{"value":false},"output20":{"value":false},"output21":{"value":false},"output22":{"value":false},"output23":{"value":false},"output24":{"value":false},"output25":{"value":false},"output26":{"value":false},"output27":{"value":false},"output28":{"value":false},"output29":{"value":false},"output30":{"value":false},"output31":{"value":false},"output32":{"value":false},"adc1":{"value":0},"adc2":{"value":0},"adc3":{"value":0},"adc4":{"value":0},}
What I tried
I tried several configuration according to the ha documentation and related topics.
for example like
value_template: "{value_json}"
state_on: '{"output1":{"value":true}}'
state_off: '{"output1":{"value":false}}'
I have no more error in HA logs but the status still unknown.
I also tried to simulate the device answer by posting directly in the MQTT server to try to understand and find a working combination but without succeed
Thanks for help
