Still a no go for me, although sometimes now seeing the message “Unknown error occurred” when attempting to authenticate.
On the subject of local tuya, will that work with tuya based light bulbs?
Well our friends at tuya believe its the only way and local control really isn’t needed as per the comment here.
The default Tuya integration started working again here. Devices work and can be controlled from HA again.
Not working for me in the UK. HomeAssistant has shown it unavailable since 00:00:12 BST 4th October, and a separate app that I have that also uses the Tuya HA API has stopped working at the same time.
Hi! Things were working as expected for me but today I’ve changed my router and I the Tuya Devices were not connecting so I’ve decided to delete the integration and reconnect.
Now I’m getting a “Unknown error ocurred” when trying to connect to the integration.
Any ideas? I even tried created another Cloud Project in the tuya platform but same error. Is there any cache in Home Assistant that I can try to delete regarding the previous integration maybe? (not sure if that’s the reason but I can’t see more information)
To add more info to it. It doesn’t matter what info I put in the 5 fields that need to be filled, real or not, I always get the Unknown error
Did you restart HA between the delete and re-install ?
I restarted HA several times yes.
Are there any logs that might give a hint as to what’s happening behind the scenes?
I don’t see anything in the HA logs relevant to that
Inspecting the network when making the resquest is returning the following:
POST
scheme
http
host
192.168.1.205:8123
filename
/api/config/config_entries/flow/e95f7a13ef1840e2aece9eeee368aefd
Response:
500 Internal Server Error
Server got itself in trouble
Can you tell me what was the solution to it? I facing this same as you now
Has anyone found a solution to this error?
