Failed Configuration
I’m still working on cleaning up this inherited Home Assistant setup. I pretty sure the configuration used to pass, but now it’s failing.
I get the following two errors:
Integration error: lutron_caseta_pro - Integration 'lutron_caseta_pro' not found.
Platform error sensor.unifigateway - Integration 'unifigateway' not found.
I haven’t moved anything or changed anything related to these integrations. There is a Lutron Caseta card in the integrations page but no Unifi Gateway. It looks like the previous admin tried to comment out the unifi gateway stuff in configuration.yaml but it’s still causing trouble.
There is a lutron_caseta_pro declaration in configuration.yaml, but it looks like it should work except for the fact that all the lutron stuff is offline due to a home rennovation. But that shouldn’t cause the configuration to fail, should it?
Any ideas?
Both of those are custom integrations, not included with home assistant. They require you to find and install them manually. If you have those in your configuration but do not have them manually installed, you’ll get those errors.
