Failed connecting to Wi-Fi | ESP8266 + Dallas 18b20
Hello, friends. I have strange problem. If I power off the ESP8266, and then power it on with a sensor attached to the board, the ESP8266 does not connect to Wi-Fi. However, if I power off the board, disconnect the sensor, power it on, it connects to Wi-Fi perfectly. After that, I connect the sensor to the working board, and everything works. I’ve tried connecting the sensor to a separate power source, leaving only the DQ contact connected to the ESP8266 - still, it doesn’t connect to Wi-Fi after powering on the board. If I disconnect the DQ contact, power on the board, and then connect the DQ contact to the powered-on board, everything works fine. Has anyone encountered a similar issue?
