Failed connections increase node counter
Hi there,
I am trying to manually connect a matter device over BLE. The device’s supplied matter code is not working and I am getting “device discriminator doesn’t match” errors.
Interestingly each failed connection increases the node counter, which has meanwhile reached 25. Not sure if there is any limit or this would be simply cosmetic. Yet I think that failed attempts should not increase the counter.
Thx
Johannes
