I’ve been running a VERY basic installation of HA for well over a year and it has been rock solid. I install all the updates as and when they are released.
I’ve recently started to become a bit more adventurous and have implemented a template, and added the Tailscale addons and all work fine.
I’m now wanting to install the HACS addon, and as a perquisite to that I’m trying to install the Terminal & SSH addon.
My problem is that I’ve tried both the official and Community versions of the SSH addon, but I get the same error with both. The addon seems to load OK, and I see a green dot in the top right of the addon info page. The error is that when I click the Terminal link in the left hand menu, I just get a blank page with a dead cursor about mid way down on the left (See attached screen capture)
For info, I’m running HA on a dedicated HP Mini PC using the native HA OS, and as of the time of writing I have all the latest HA updates installed and HA is running all my other addons, automations, dashboards etc. just fine.
I’ve tried many uninstall/re-install, reboots etc. but always have the same issue.
If it helps, the following is a copy of one of the logs from the Community version…
Add-on: Advanced SSH & Web Terminal
A supercharged SSH & Web Terminal access to your Home Assistant instance
Add-on version: 20.0.2
You are running the latest version of this add-on.
System: Home Assistant OS 15.2 (amd64 / generic-x86-64)
Home Assistant Core: 2025.4.4
Home Assistant Supervisor: 2025.04.1
Please, share the above information when looking for help
or support in, e.g., GitHub, forums or the Discord chat.
s6-rc: info: service base-addon-banner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service base-addon-log-level: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service base-addon-log-level successfully started
s6-rc: info: service legacy-cont-init: starting
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service init-ssh: starting
s6-rc: info: service init-mysql: starting
s6-rc: info: service init-mosquitto: starting
s6-rc: info: service init-docker: starting
s6-rc: info: service init-mysql successfully started
s6-rc: info: service init-docker successfully started
s6-rc: info: service init-mosquitto successfully started
[16:56:14] WARNING:
[16:56:14] WARNING: Logging in with a SSH password is security wise, a bad idea!
[16:56:14] WARNING: Please, consider using a public/private key pair.
[16:56:14] WARNING: What is this? https://kb.iu.edu/d/aews
[16:56:14] WARNING:
[16:56:14] NOTICE: Session sharing has been disabled!
s6-rc: info: service init-user successfully started
s6-rc: info: service ttyd: starting
s6-rc: info: service sshd: starting
s6-rc: info: service sshd successfully started
s6-rc: info: service ttyd successfully started
s6-rc: info: service legacy-services: starting
[16:56:14] INFO: Starting the ttyd daemon...
[16:56:14] INFO: Starting the SSH daemon...
Server listening on 0.0.0.0 port 22.
Server listening on :: port 22.
s6-rc: info: service legacy-services successfully started
