Failed to add Mosquitto Broker in Home Assistant
I m new here and the following drives me crazy when adding Mosquitto Broker in HA,
Any help? Thanks a lot!
David
Go to Settings → System → Network → IPv4
Check your DNS server setting. Try 1.1.1.1 or 8.8.8.8
Thanks so much, but it didnot work and seems this is a docker Hub mirro issue? after looking it up on chatGDP, but not pretty sure.
Tom’s right.
It’s always DNS…
Context deadline exceeded could be a network or DNS issue. Or because the Docker engine lacks resources (memory or disk space).
Do you have enough resources in your Home Assistant itself ? aarch64 means it is ARM based. Is this a Pi ?
