Am getting the following error when trying to install Home Assistant on Windows 10 with Python 3.8. Can anyone suggest how to fix?
Building wheels for collected packages: ciso8601
Building wheel for ciso8601 (pyproject.toml) ... error
ERROR: Command errored out with exit status 1:
command: /srv/homeassistant/bin/python3.8 /srv/homeassistant/lib/python3.8/site-packages/pip/_vendor/pep517/in_process/_in_process.py build_wheel /tmp/tmpohpzfew9
cwd: /tmp/pip-install-6pgrb52e/ciso8601_167a94d915954737a7b3c59b6a26e024
Complete output (14 lines):
running bdist_wheel
running build
running build_py
package init file 'ciso8601/__init__.py' not found (or not a regular file)
creating build
creating build/lib.linux-x86_64-3.8
creating build/lib.linux-x86_64-3.8/ciso8601
copying ciso8601/__init__.pyi -> build/lib.linux-x86_64-3.8/ciso8601
copying ciso8601/py.typed -> build/lib.linux-x86_64-3.8/ciso8601
running build_ext
building 'ciso8601' extension
creating build/temp.linux-x86_64-3.8
x86_64-linux-gnu-gcc -pthread -Wno-unused-result -Wsign-compare -DNDEBUG -g -fwrapv -O2 -Wall -g -fstack-protector-strong -Wformat -Werror=format-security -g -fwrapv -O2 -g -fstack-protector-strong -Wformat -Werror=format-security -Wdate-time -D_FORTIFY_SOURCE=2 -fPIC -DCISO8601_VERSION=2.2.0 -DCISO8601_CACHING_ENABLED=1 -I/srv/homeassistant/include -I/usr/include/python3.8 -c module.c -o build/temp.linux-x86_64-3.8/module.o
error: command 'x86_64-linux-gnu-gcc' failed with exit status 1
ERROR: Failed building wheel for ciso8601
Failed to build ciso8601
ERROR: Could not build wheels for ciso8601, which is required to install pyproject.toml-based projects
