Failed to call service yeelight.start_flow. Unknown error
I’m trying to set up an automation for an alarm to strobe a light when triggered until disarmed, then return the light to its previous state.
I’ve tried many things such as saving and restoring scenes and nothing really has worked.
I read through the Yeelight docs and noted that flows have a “recover” action when the flow stops, but I just can’t get it to work, even when copy-pasting the example in the development tools area. I’ve scoured forums and the internet but I can’t find anything, or even a full example of the flows service call. I get following after correct (I believe) syntax:
“Failed to call service yeelight.start_flow. Unknown error”
Here’s my yaml:
service: yeelight.start_flow
  device_id: bf1162696f8ad8330a200a5fb182947f
  count: 1
  action: recover
  transitions:
    - TemperatureTransition:
        - 1900
        - 1000
        - 80
        - 1900
        - 1000
        - 10
Help is appreciated.
I just had the same issue. I’m not sure why it’s happening, but referencing the entity_id instead of device_id fixed it for me.
Thanks so much! That got it working! I appreciate you signing up just to post this for me.
I’ll endeavour to create an issue on GitHub to hopefully fix this for others.
thank you so much.
I have been trying to find the problem in transitions the whole time and have always selected the lamp via devices.
With Entity it works directly!
