New to Coding/Pi/HASS, so please be patient (didn’t see a beginners section).
I followed a few youtube videos and got Hass.io set up on my RPi3. Im currently running into an issue trying to add z-wave nodes (or anything associated with z-wave, I get the same warning, just followed with the command requested).
I have Z-Wave Intergration set
I have the following placed in configuration.yaml:
zwave:
usb_path: /dev/ttyACM0
(Ive tried using /ttyUSB0 as well)
Here is a grab from the log file:
2018-12-15 16:19:18 WARNING (Recorder) [homeassistant.components.recorder] Ended unfinished session (id=14 from 2018-12-15 21:50:26.759970)
2018-12-15 16:19:21 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry Z-Wave (import from configuration.yaml) for zwave
File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 78, in init
raise ZWaveException(u"Can’t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: “Zwave Generic Exception : Can’t find device /dev/ttyACM0 : [‘NoneType: None\n’]”
File “/usr/local/lib/python3.6/site-packages/homeassistant/config_entries.py”, line 249, in async_setup
result = await component.async_setup_entry(hass, self)
File “/usr/local/lib/python3.6/site-packages/homeassistant/components/zwave/init.py”, line 283, in async_setup_entry
config_path=config.get(CONF_CONFIG_PATH))
File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 81, in init
raise ZWaveException(u"Error when retrieving device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))
openzwave.object.ZWaveException: ‘Zwave Generic Exception : Error when retrieving device /dev/ttyACM0 : [‘Traceback (most recent call last):\n’, ’ File “/usr/local/lib/python3.6/site-packages/openzwave/option.py”, line 78, in init\n raise ZWaveException(u"Can\‘t find device %s : %s" % (device, traceback.format_exception(*sys.exc_info())))\n’, ‘openzwave.object.ZWaveException: “Zwave Generic Exception : Can\'t find device /dev/ttyACM0 : [\‘NoneType: None\\\\n\’]”\n’]’
Using a USB Z-Wave hub (Nortek HUSBZB-1)
Uploaded screenshot of error included. Please let me know if you need anything else to help me diagnose this.
