I have verified the USB stick is at the correct location, /dev/ttyACM0
The zwave UI is showing in the web interface, trying to add node, or perform action only results in: WARNING (MainThread) [homeassistant.core] Unable to find service zwave/add_node_secure
I did notice the users/groups on the USB are: crw-rw---- and root:audio whichs eems odd.
At least from the log snipit it may be that the driver failed to load or crashed. I donât know how you have it installed or what logs you may have access to, but if you can. check the system logs for cdc_acm driver references.
To see if the driver is loaded lsmod |grep cdc_acm
grep cdc_acm /var/log/syslog
or dmesg | grep cdc_acm
you could try modprobe cdc_acm to see if the driver loads if it isnât???
Having the exact same issue, just doing a fresh install and canât get Z-wave working. Tried loading it through Integrations and via configuration.yaml and it is no good.
Ok, so i believe i might be able to help now that i got it working
Click in the Main menu Hass.io -> System
Then click HARDWARE under Host Name
You should get a listing under Serial that looks something like this
serial:
/dev/ttyAMA0
/dev/ttyACM0
So most likely one of those is your USB Z-wave stick.
For whatever reason the Configuration.yaml and the Z-Wave settings arenât passing the proper info to the Core Components of Home Assistant.
So go to Hassio\config.storage
There is a file there called âcore.config_entriesâ
Open the file
you should see âusb_pathâ: â/dev/ttyACM0â
Change the in quotes section to whatever you came up with from the serial devices. Save this. Try one and reboot it Hass.io, if it works, great. If not try the other device.
Hi, my zwave was working fine until I updated to the latest version. I am looking for the â/config/.storage/core.config_entriesâ file, but I cannot find it. Iâm using finder in Mac OS.
Never mind, I found the file through Hass Configurator. The usb_path appears to be correct though.
Never mind 2: The z stick has come up now for no apparent reason.
I can also confirm that manually updating .storage/core.config_entries to /dev/ttyACM0 worked for me. I also updated configuration.yaml for my own sake.
Donât know if this can save some poor other home-assistant noob like me some minutes but simple restart did the trix for me. Guess that will be my first thing I do when I run into troubles with HASSIO
In the case someone is trying to get an Aeotec Z-Wave gen5 USB stick working with a Raspberry Pi 4, there is something wonky with how the Pi 4 and the stick interface (something about power) and the Pi wonât see the stick at all. The workaround is to use a hub. There is a discussion on the Pi forums.
