An error occurred when I ran the operating-system in the official way
- I ran this command—>
sudo scripts/enter.sh make rpi3_64
123@123-ha:~/work/operating-system$ sudo scripts/enter.sh make rpi3_64
[+] Building 0.9s (10/10) FINISHED
=> [internal] load build definition from Dockerfile 0.0s
=> => transferring dockerfile: 1.35kB 0.0s
=> [internal] load .dockerignore 0.0s
=> => transferring context: 99B 0.0s
=> [internal] load metadata for docker.io/library/debian:bullseye 0.7s
=> [1/5] FROM docker.io/library/debian:bullseye@sha256:a648e10e02af129706b1fb89e1ac9694ae3db7f2b8439aa906321e68cc281bc0 0.0s
=> [internal] load build context 0.0s
=> => transferring context: 65B 0.0s
=> CACHED [2/5] RUN apt-get update && apt-get install -y --no-install-recommends apt-transport-https ca-certificate 0.0s
=> CACHED [3/5] RUN apt-get update && apt-get install -y --no-install-recommends bash bc binutils b 0.0s
=> CACHED [4/5] COPY scripts/entry.sh /usr/sbin/ 0.0s
=> CACHED [5/5] WORKDIR /build 0.0s
=> exporting to image 0.0s
=> => exporting layers 0.0s
=> => writing image sha256:1b1d84ccb37c5e5579fd08a0a8fa1b756b26bccf78d873c0c7efde2752280c12 0.0s
=> => naming to docker.io/library/hassos:local 0.0s
WARNING: buildx: failed to read current commit information with git rev-parse --is-inside-work-tree
config rpi3_64
/usr/bin/make -C /build/buildroot O=/build/output BR2_EXTERNAL=/build/buildroot-external "rpi3_64_defconfig"
make[1]: Entering directory '/build/buildroot'
GEN /build/output/Makefile
# configuration written to /build/output/.config
make[1]: Leaving directory '/build/buildroot'
build rpi3_64
/usr/bin/make -C /build/buildroot O=/build/output BR2_EXTERNAL=/build/buildroot-external VERSION_DEV="dev20230713"
/usr/bin/make -j1 O=/build/output HOSTCC="/usr/bin/gcc" HOSTCXX="/usr/bin/g++" syncconfig
make[2]: Entering directory '/build/buildroot'
make[2]: Leaving directory '/build/buildroot'
>>> hassio 1.0.0 Installing to images directory
/build/buildroot-external/package/hassio/create-data-partition.sh "/build/output/build/hassio-1.0.0" "/build/output/images"
mke2fs 1.46.2 (28-Feb-2021)
Discarding device blocks: done
Creating filesystem with 327680 4k blocks and 81920 inodes
Filesystem UUID: 18d74762-b4be-4ca9-87f7-7345d86611b3
Superblock backups stored on blocks:
32768, 98304, 163840, 229376, 294912
Allocating group tables: done
Writing inode tables: done
Creating journal (8192 blocks): done
Writing superblocks and filesystem accounting information: done
Unable to find image 'docker:20.10-dind' locally
20.10-dind: Pulling from library/docker
8a49fdb3b6a5: Pull complete
db1d8fde5ab0: Pull complete
f3759a44eb9f: Pull complete
1465fd8ca4ab: Pull complete
95c1bc752a8b: Pull complete
f5ce33fb9a21: Pull complete
4d37eec86745: Pull complete
49d0e23604c0: Pull complete
ac56a29f30eb: Pull complete
0184c8e99504: Pull complete
23430c064101: Pull complete
e2a9b00eaf87: Pull complete
004faac3bc86: Pull complete
765a9f2e0717: Pull complete
Digest: sha256:af96c680a7e1f853ebdd50c1e0577e5df4089b033102546dd6417419564df3b5
Status: Downloaded newer image for docker:20.10-dind
Waiting for Docker daemon...
Loading container images...
Loaded image: ghcr.io/home-assistant/aarch64-hassio-audio:2023.06.0
open /var/lib/docker/tmp/docker-import-643693548/repositories: no such file or directory
make[1]: *** [package/pkg-generic.mk:374: /build/output/build/hassio-1.0.0/.stamp_images_installed] Error 1
make: *** [Makefile:39: rpi3_64] Error 2
What I use is
167~18.04.1-Ubuntu SMP Wed May 24 00:51:42 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
docker version
Docker version 24.0.2, build cb74dfc
- Somebody help me
