Failed to Connect NSURLErrorDomain -1200
For the last few days I’ve been unable to my server using the IOS app. I get a “Failed to Connect” error.
“An SSL error has occurred and a secure connection to the server cannot be made.”
Error Code:
Log recorded this:
Logger: aiohttp.server
Source: /usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py:393
First occurred: 7:20:23 PM (6 occurrences)
Last logged: 7:22:21 PM
Error handling request
  File "/usr/local/lib/python3.9/site-packages/aiohttp/web_protocol.py", line 314, in data_received
    messages, upgraded, tail = self._request_parser.feed_data(data)
  File "aiohttp/_http_parser.pyx", line 546, in aiohttp._http_parser.HttpParser.feed_data
aiohttp.http_exceptions.BadStatusLine: 400, message="Bad status line 'invalid HTTP method'"
I’m pretty new to this, so any guidance would be greatly appreciated. Thanks!
Any info on your setup would be greatly appreciated by anyone reading your question as well :wink:
Who/how is your SSL handled?
I was having the same issue. The root of it was that at one point i had logged in and tried Nabu Casa, but then switched to using my own reverse proxy. When logging in from the companion app, it sees your nabu casa login and still tries to connect to it, but since my subscription expired, it just gives SSL errors on the nabu casa url.
To fix:
  • Log in to your HA web admin portal
  • Go to Configuration > Home Assistant Cloud
  • Click the three dots in the top right
  • Click “Sign out”
Then try to log in to the companion app on iOS again and it should work.
Thank you this worked perfectly for me
Hi!
I got the same problem today. I could not login via the ios app. The solution above failed. I was already logged out from the cloud.
Instead I opened the config in the app and checked the instance where I login. I said I’m logging in via the cloud. When I disabled this it started to work again.
