So I’m trying to set up DDNS and I get this error no matter what I do.
starting version 3.2.2
# INFO: Using main config file /data/workdir/config
+ Generating account key...
+ Registering account key with ACME server...
ERROR: Problem connecting to server (post for https://acme-v01.api.letsencrypt.org/acme/new-reg; curl returned with 52)
It seems like Hassio has generated the key but cannot connect to letsencrypt for some reason. I have forwarded every port I can think of to get this to work, but always get the same error.
Any ideas?
I also ran
curl -v https://acme-v01.api.letsencrypt.org/directory
and it seems to work just fine so I’m not sure what else to do here
thanks,
William
