Failed to create HTTP server at port - Errno 13
Team,
I have a router with somewhat limited port forwarding options. As described in the alexa section REQUIREMENTS note 2 I have attempted to set Home Assistant serving port to 443 with the following in my config.yaml
http:
server_host: 192.168.0.2
server_port: 443
However, I get the following in my log file
2017-11-14 19:09:39 ERROR (MainThread) [homeassistant.components.http] Failed to create HTTP server at port 443: [Errno 13] error while attempting to bind on address (‘192.168.0.2’, 443): permission denied
Errno 13 is apparently incorrect user, so my question is this; How can I get round this issue or do I need to run as a different user?
BTW I’ve tried this on a fresh install of Hassbian and I get the same results.
Cheers once again for your collective and fantastic help
