Zigbee running off HUSBZB-1 for a few months now problem free. Today I’ve encountered “Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>” for several of my in-wall Enbrighten Zigbee switches. Nothing changed on the configuration side. ZHA Zigbee. Running on a VM Windows 11. Reset server, reset devices. Any ideas?
Error log reads as follows:
Logger: homeassistant.components.websocket_api.http.connection
Source: components/zha/light.py:360
Integration: Home Assistant WebSocket API (documentation, issues)
First occurred: 2:11:35 PM (11 occurrences)
Last logged: 2:31:16 PM
[140321278311312] Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
File “/usr/src/homeassistant/homeassistant/components/websocket_api/commands.py”, line 205, in handle_call_service
await hass.services.async_call(
File “/usr/src/homeassistant/homeassistant/core.py”, line 1965, in async_call
response_data = await coro
File “/usr/src/homeassistant/homeassistant/core.py”, line 2005, in _execute_service
return await cast(
File “/usr/src/homeassistant/homeassistant/helpers/entity_component.py”, line 235, in handle_service
return await service.entity_service_call(
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 848, in entity_service_call
response_data = task.result() # pop exception if have
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1192, in async_request_call
return await coro
File “/usr/src/homeassistant/homeassistant/helpers/service.py”, line 892, in _handle_entity_call
result = await task
File “/usr/src/homeassistant/homeassistant/components/light/init.py”, line 582, in async_handle_light_on_service
await light.async_turn_on(**filter_turn_on_params(light, params))
File “/usr/src/homeassistant/homeassistant/components/zha/light.py”, line 360, in async_turn_on
result = await self._on_off_cluster_handler.on()
File “/usr/local/lib/python3.11/site-packages/zigpy/util.py”, line 132, in retry
return await func()
File “/usr/local/lib/python3.11/site-packages/zigpy/zcl/init.py”, line 375, in request
return await self._endpoint.request(
File “/usr/local/lib/python3.11/site-packages/zigpy/endpoint.py”, line 253, in request
return await self.device.request(
File “/usr/local/lib/python3.11/site-packages/zigpy/device.py”, line 293, in request
await self._application.request(
File “/usr/local/lib/python3.11/site-packages/zigpy/application.py”, line 824, in request
await self.send_packet(
File “/usr/local/lib/python3.11/site-packages/bellows/zigbee/application.py”, line 831, in send_packet
raise zigpy.exceptions.DeliveryError(
zigpy.exceptions.DeliveryError: Failed to deliver message: <EmberStatus.DELIVERY_FAILED: 102>
