I was going to post this at github but it’s very specific that if you are using HA post here unless told otherwise. Here’s the story.
Been using an Aeotec Z-Wave Gen5 stick (firmware 1.01) for years without issue. There have been no changes physically to my Z-Wave environment or placement. My prior system was running in a VMWare Workstation virtual with the Z-Wave stick passed thru and same Z-WaveJS UI back but in the virtual. Worked fine.
My new environment is a new computer running Windows 2022 with the Hyper-V Role. It is running Z-WaveJS UI on the physical server. Z-Wave JS info:
zwave-js-ui: 8.8.0
zwave-js: 10.4.0
Do not think this is HA related and probably all local because my HA shows nothing in the logs. Ever since moving to the new setup I’m having issues where the Z-Wave devices stop responding or do but slow. My HA screen also do not update anymore when this happens though you can still click the switches even though they may not update and eventually get a reaction from a device. Like 30 seconds later. If I pull the stick out and plug it back in problem goes away for an indeterminate period of time. If I reboot the computer same deal. Believe this is also accurate. If I restart Z-Wave JS UI it doesn’t help. What I’ve tried:
- Installing the Aeotec Z-Wave driver in Windows
- Change and resetting the COM port speed
- Had an external hard drive also plugged into the front USB 2.0 ports and removed that.
- Tried healing multiple times which works fine but fails when things aren’t responding.
- Updated the stick to 1.02.
Probably tried some other things but at a loss right now. Any thoughts? Thought there was a way to attach logs but not seeing it right now so some examples of what’s going on:
023-02-01T22:42:18.441Z CNTRLR [Node 007] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2023-02-01T22:42:18.941Z SERIAL » 0x010a0013070325010025f310 (12 bytes)
2023-02-01T22:42:18.941Z DRIVER » [Node 007] [REQ] [SendData]
│ transmit options: 0x25
│ callback id: 243
└─[BinarySwitchCCSet]
target value: false
2023-02-01T22:42:19.942Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:42:20.052Z SERIAL » 0x010a0013070325010025f310 (12 bytes)
2023-02-01T22:42:20.052Z DRIVER » [Node 007] [REQ] [SendData]
│ callback id: 243
target value: false
2023-02-01T22:42:21.068Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:42:22.169Z SERIAL » 0x010a0013070325010025f310 (12 bytes)
2023-02-01T22:42:22.169Z DRIVER » [Node 007] [REQ] [SendData]
│ callback id: 243
target value: false
2023-02-01T22:42:23.178Z CNTRLR [Node 007] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2023-02-01T22:42:23.695Z SERIAL » 0x010a0013070325010025f310 (12 bytes)
2023-02-01T22:42:23.695Z DRIVER » [Node 007] [REQ] [SendData]
│ callback id: 243
target value: false
2023-02-01T22:42:24.696Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:42:24.805Z SERIAL » 0x010a0013070325010025f310 (12 bytes)
2023-02-01T22:42:24.805Z DRIVER » [Node 007] [REQ] [SendData]
│ callback id: 243
target value: false
2023-02-01T22:42:25.820Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:42:26.928Z SERIAL » 0x010a0013070325010025f310 (12 bytes)
2023-02-01T22:42:26.928Z DRIVER » [Node 007] [REQ] [SendData]
│ callback id: 243
target value: false
2023-02-01T22:46:10.490Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:10.491Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
└─[MultilevelSwitchCCSet]
target value: 79
duration: default
2023-02-01T22:46:11.507Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:46:11.616Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:11.616Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:46:12.632Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:46:13.742Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:13.743Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:46:14.744Z CNTRLR [Node 014] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2023-02-01T22:46:15.260Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:15.261Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:46:16.271Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:46:16.381Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:16.381Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:46:17.395Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:46:18.505Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:18.505Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:46:19.521Z CNTRLR [Node 014] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2023-02-01T22:46:20.024Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:20.024Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:46:21.039Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:46:21.148Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:21.149Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:46:22.149Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:46:23.259Z SERIAL » 0x010b00130e0426014fff25f4ab (13 bytes)
2023-02-01T22:46:23.259Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 244
target value: 79
duration: default
2023-02-01T22:47:22.038Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:22.038Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:23.047Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:47:23.157Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:23.157Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:24.172Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:47:25.282Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:25.282Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:26.298Z CNTRLR [Node 014] did not respond after 1/3 attempts. Scheduling next try in 500 ms.
2023-02-01T22:47:26.815Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:26.815Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:27.825Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:47:27.934Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:27.934Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:28.936Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:47:30.045Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:30.046Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:31.047Z CNTRLR [Node 014] did not respond after 2/3 attempts. Scheduling next try in 500 ms.
2023-02-01T22:47:31.562Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:31.563Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:32.579Z CNTRLR Failed to execute controller command after 1/3 attempts. Scheduling next try i
n 100 ms.
2023-02-01T22:47:32.688Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:32.688Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
2023-02-01T22:47:33.689Z CNTRLR Failed to execute controller command after 2/3 attempts. Scheduling next try i
n 1100 ms.
2023-02-01T22:47:34.804Z SERIAL » 0x010b00130e04260128ff25f5cd (13 bytes)
2023-02-01T22:47:34.805Z DRIVER » [Node 014] [REQ] [SendData]
│ callback id: 245
target value: 40
duration: default
Adding a picture. When it’s like this you see ACK timeouts and heals fail
