Failed to install: node-red-contrib-ttn
For my project i like to install node-red-contrib-tnn and get TTN nodes in my pallete to work with.
However i get Failed to install: node-red-contrib-ttn
I run HA on a Raspi4
Systeemstatus
|arch|armv7l| | --- | --- | |dev|false| |docker|true| |hassio|true| |os_name|Linux| |os_version|4.19.114-v7l| |python_version|3.7.7| |timezone|Europe/Amsterdam| |version|0.109.4| |virtualenv|false|
Help needed to get it installed! See attachment below!
ttn|690x318
Have you done a bit of research?
  1. Go to flows.noreded.org (the “library” for all palettes)
  2. Search for node-red-contrib-ttn
  3. Go to the github page of this node (https://github.com/TheThingsNetwork/nodered-app-node)
  4. And:
:warning: These nodes are not supported on Raspberry Pi :warning:
End of story…
GV
Thanks you for this. Loud and clear. To bad this dont work on a raspberry pi. It would be handy because of the form factor.
