I noticed the connection to my Hass was down this morning and would not let me log in. After a reboot it came back up, but now I can not access the Hass.io panel. It says ‘Failed to load Hass.io panel from supervisor’.
I searched on forums, but none of the suggestions worked for me (i.e. clearing browser settings). I have tried it on multiple devices to rule out anything with the browser. Any ideas?
I am currently on version 0.60.0 and probably need to update, but can’t with it not currently letting me into the hass.io panel.
same here 2018-06-02 11:19:28 ERROR (MainThread) [custom_components.hassio] /homeassistant/options return code 401. 2018-06-02 11:19:28 ERROR (MainThread) [custom_components.hassio] /supervisor/options return code 401.
still using 0.69.1
edit: ok, I got rid of config files in the custom_components subfolder in the config folder. The errors disappeared. Firefox is still not working, but for Chrome this this is working just fine.
That’s interesting. I only have media player components for my PS4 in that folder. Would rather not remove them if possible, but will if that is the only way to resolve.
Problem is what ever the fix is I can’t update without the Hass.io panel. SSH isn’t working for me either. I think my only option now is to flash my SD card, re-install and use an old backup file I have from a few months back to get most of what I had running again.
