Failed to load integration for translation: Integration 'volumes' not found
So I just set up my HA server via Docker/Portainer just awhile back. Got everything up and running and no issues so far in terms of function. However, I am getting this constant notification that I have failed to load integration for translation as well as Setup failed for ‘volumes’: Integration not found.
Since my HA server is functioning properly, I don’t know where to trace this error. Any help would be greatly appreciated
“2024-03-20 17:59:00.684 WARNING (MainThread) [homeassistant.helpers.translation] Failed to load integration for translation: Integration ‘volumes’ not found.
2024-03-20 17:59:10.660 ERROR (MainThread) [homeassistant.setup] Setup failed for ‘volumes’: Integration not found.”
Screenshot 2024-03-20 193503
I have the same thing but i get areas not volumes
Home Assistant Core
Setup failed for ‘areas’: Integration not found.
09:00:40 – (ERROR) setup.py
Failed to load integration for translation: Integration ‘areas’ not found.
09:00:36 – (WARNING) helpers/translation.py
Hope we find a solution! Your HASS works fine?
I still have this showing. Anyone solve it ?
Yo tengo el mismo problema y no se que hacer
Registrador: homeassistant.helpers.translation
Fuente: helpers/translation.py:226
Ocurrió por primera vez: 12:37:04 (1 ocurrencias)
Último inicio de sesión: 12:37:04
Failed to load integration for translation: Integration ‘-notify’ not found.
Registrador: homeassistant.setup
Fuente: setup.py:269
Ocurrió por primera vez: 12:37:05 (1 ocurrencias)
Último inicio de sesión: 12:37:05
Setup failed for ‘-notify’: Integration not found.
Same issue, no idea what is causing it. Have this since a couple of weeks. HA (on Yellow) seems to run fine.
How do I solve this error?
Thanks for the support
I have the same exact errrors.
I started getting a similar issue since Upgrading to 2024.11
This breaks a few views for me, eg. If I try to view Backups or HACS, I just see a white screen (with the toolbar still to the left)
This is the Warning and Error I get.
Logger: homeassistant.helpers.translation
Source: helpers/translation.py:226
First occurred: 9:15:46 AM (1 occurrences)
Last logged: 9:15:46 AM
Failed to load integration for translation: Integration 'panel_iframe' not found.
Logger: homeassistant.setup
Source: setup.py:269
First occurred: 9:15:47 AM (1 occurrences)
Last logged: 9:15:47 AM
Setup failed for 'panel_iframe': Integration not found.
I hope someone can help
I found this panel_iframe integration was used in my configuration.yaml. In my case it was to have a side menu item for portainer to manage the docker images I use in my setup.
I removed it from the configuration.yaml and will try to figure out later how to replace it but I never used it so I might leave it removed…
I solved my error by removing in configuration.yaml the resources bit.
resources:
  - url: /local/apexcharts-card.js?v=2.0.4
    type: module
Move resources to Lovelace Configuration
If you need to load custom resources (e.g., for the ApexCharts card), you should configure them in the Lovelace UI or in a separate Lovelace YAML file.
Configure in the Lovelace UI
  1. Go to **Settings > Dashboards > Resources.
  2. Add the resource URL for the ApexCharts card (or any other custom card).
Then reload HA and when starting up no more errors
Guys, saying “same here”, “me too” or “no fix” is about as useful as “sending thoughts and prayers”.
Just leave a like on the topic or follow @Benneton’s (unfromatted) advice or create a github issue if you want to be notified of any progress. If you really want to help, create a github issue and post your logs so that the devs can isolate what is causing it.
