Failed to load the hassio panel from supervisor
Hi, I did the 045 upgrade and it seems that failed at some point.
I get a 401 error
Looks like you’re running Chrome. Be sure to do a ctrl-F5 refresh and/or clear your cache. Chome’s caching in recent versions is pretty aggressive.
Same issue with other devices
Same issue here too.
Same issue here - it started after I configured a password.
Yes that will fix with 0.45.1
That is if you have set a password on HomeAssistant.
have this error, I am on 0.54.
DO not understand the above instrucitions … which password to remove? (I do not have in http:)
