"Failed to parse configuration.yaml: invalid key" After Upgrade to 7.0
I just updated from 6.6 to 7.0 this morning and after I did, my HA activated safe mode with the following error:
2021-12-11 10:49:52 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] invalid key: "OrderedDict([('(range(3', None), ('10)|random)', None)])"
in "/config/automations.yaml", line 383, column 0
2021-12-11 10:49:52 ERROR (MainThread) [homeassistant.bootstrap] Failed to parse configuration.yaml: invalid key: "OrderedDict([('(range(3', None), ('10)|random)', None)])"
in "/config/automations.yaml", line 383, column 0. Activating safe mode
When I checked my configuration.yaml for that line, it’s failing on the delay portion of this (commented out so HA would start up again):
- id: automation.timer_devices_on
  alias: Timer Devices - On
  description: Turns on the timer lights and switches 3 minutes after sunset with pauses between devices.
  - platform: sun
    event: sunset
    offset: 00:03:00
    - service: light.turn_on
        entity_id: light.great_room_couch_lamp
#    - delay:
#        seconds: {{ (range(3, 10)|random) }}
Again, this exact code worked fine in 6.6.
Just updated to 7.1 and this is still happening.
2022-01-03 12:11:56 ERROR (SyncWorker_0) [homeassistant.util.yaml.loader] invalid key: "OrderedDict([('(range(3', None), ('10)|random)', None)])"
in "/config/automations.yaml", line 345, column 0
2022-01-03 12:11:56 ERROR (MainThread) [homeassistant.bootstrap] Failed to parse configuration.yaml: invalid key: "OrderedDict([('(range(3', None), ('10)|random)', None)])"
in "/config/automations.yaml", line 345, column 0. Activating safe mode
