After an update from 2024.4.1 to 2024.4.2, my coordinator dongle Sonoff Zigbee 3.0 USB model E, under ZHA, didn’t work anymore. I tried multiple things advised in this forum in different threads:
Tried to reload / reconfigure → failed
Went back to 2024.4.1 with a backup I had → failed
Removed the USB dongle, replugged, restarted the machine where it’s plugged, … → failed
Uninstalled the ZHA integration, tried to reinstall it → failed (Failed to probe the usb device)
I tried to change the permissions sudo chmod a+rwx /dev/ttyACM0 → failed
In /dev/serial/by-id, I see: usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20221029134549-if00
A few more information:
It is an installation on a Debian Linux (through YunoHost).
Everything was working fine up to now.
I never flashed the device, I think it has the recommended firmware (ncp-uart-sw_EZNet6.10.3_V1.0.1).
The device appears to be connected on /dev/ttyACM0: crw-rw---- 1 root dialout 166, 0 Apr 11 15:47 ttyACM0
I just see this in the log, but I don’t find this helpful. Would it give an idea to anybody?
Logger: homeassistant
Source: /var/www/homeassistant/lib/python3.12/site-packages/homeassistant/runner.py:146
First occurred: 17:32:29 (5 occurrences)
Last logged: 17:34:25
Error doing job: Exception in callback SerialTransport._read_ready()
ValueError: (11, None) is not a valid NcpResetCode
File "/usr/local/lib/python3.12/asyncio/events.py", line 88, in _run
self._context.run(self._callback, *self._args)
File "/var/www/homeassistant/lib/python3.12/site-packages/serial_asyncio_fast/__init__.py", line 137, in _read_ready
self._protocol.data_received(data)
File "/var/www/homeassistant/lib/python3.12/site-packages/bellows/uart.py", line 84, in data_received
self.frame_received(frame)
File "/var/www/homeassistant/lib/python3.12/site-packages/bellows/uart.py", line 119, in frame_received
self.rstack_frame_received(data)
File "/var/www/homeassistant/lib/python3.12/site-packages/bellows/uart.py", line 160, in rstack_frame_received
code, version = self._get_error_code(data)
File "/var/www/homeassistant/lib/python3.12/site-packages/bellows/uart.py", line 193, in _get_error_code
return t.NcpResetCode(data[2]), data[1]
File "/var/www/homeassistant/lib/python3.12/site-packages/bellows/types/basic.py", line 216, in __call__
return super().__call__(value, names, *args, **kwargs)
File "/usr/local/lib/python3.12/enum.py", line 757, in __call__
return cls.__new__(cls, value)
File "/usr/local/lib/python3.12/enum.py", line 1179, in __new__
raise exc
File "/usr/local/lib/python3.12/enum.py", line 1156, in __new__
result = cls._missing_(value)
File "/var/www/homeassistant/lib/python3.12/site-packages/bellows/types/basic.py", line 225, in _missing_
new = int_type.__new__(cls, value)
TypeError: int() argument must be a string, a bytes-like object or a real number, not 'tuple'
Same here. But when updating to 2024.4.4. The 2024.4.3 version worked fine.
I have Homassistant running in a VM on Proxmox. Never had any problems with the Sonoff Dongle before.
The dongle seems to be present in the VM. UART is there. But Homeassistant cant connect to it.
for me 2024.4.3 did not work and now I installed 2024.4.4 which did not solve the problem, too.
I also tried as device instead of /dev/ttyACM0
This device: /dev/serial/by-id/usb-ITEAD_SONOFF_Zigbee_3.0_USB_Dongle_Plus_V2_20231216171152-if00
But did also not help
Using also 115200 as speed and software flow control.
@solidminds do you use it on a raspberry pi on proxmox or a “normal” x86 computer?
I’m on a Raspberry Pi 5 and thought if some firmware settings may be needed.
I found a solution. The problem is because of Python 3.12.3 - there was a change which made ZHA incompatible.
Seems there was an update of bellows package (4 hours ago) which fixes zha problems.
