Hi, looking for some help please (getting a bit technical for me to resolve). When I reboot from Home Assistant front end (an infrequent activity) it seems to get stuck and fails. Once the above message is received I can’t connect to HA via the front end or SSH. I need to pull the power and restart, everything then returns to normal.
Whilst this isn’t a significant issue currently, worried there is something underlying that may get worse. Recently upgraded to 4.13, previously didn’t have any issues. Had a troll through the logs but as I don’t really know what I’m looking for struggled to find anything that would help, did find something that says fatal!
File "/usr/local/lib/python3.8/asyncio/events.py", line 81, in _run
self._context.run(self._callback, *self._args)
File "/usr/src/homeassistant/homeassistant/core.py", line 731, in onetime_listener
self._hass.async_run_job(listener, event)
File "/usr/src/homeassistant/homeassistant/core.py", line 386, in async_run_job
self.async_add_job(target, *args)
File "/usr/src/homeassistant/homeassistant/core.py", line 316, in async_add_job
task = self.loop.create_task(target(*args))
TypeError: stop() takes 1 positional argument but 2 were given
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] waiting for services.
Client error on /homeassistant/restart request
s6-svscanctl: fatal: unable to control /var/run/s6/services: supervisor not listening
I’ve attached the logs for core, host and supervisor if that helps.
Any advise would be really gratefully received.
