Failed to Reload configuration
I don’t really know how it happened, but something broke in the configuration. I can’t restore a backup, and I can’t reset it. I’m getting this message - does anyone know how to fix it? I cant also open file editor for editing the Yaml file.
Seems there is something wrong in your automations.yaml.
I appreciate your help, but how can I resolve this issue?
If you paste the first 10-20 lines of the file here correctly formatted I can take a look.
How may I access the file? I can’t start the file editor also
Try removing the file editor add-on and installing it again.
tried, unfortunately the same
You can try installing the Samba file share add-on and access it through that.
Or use the ssh addon.
